Xantia front suspension
froggy
(Donor 2026)
x 4
Unread post by froggy »
Hi, my series1 Xantia front suspension is suddenly on high. when I do some citroen aerobics,,,,it will move to high then straight down to low setting, it doesn't seem to reconise the middle setting, any ideas ? cheers Terry. :(
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
x 1438
Re: Xantia front suspension
Unread post by xantia_v6 »
The plastic "dog-bone" link between the roll bar and the height corrector has probably popped off, or the steel arm on the roll bar has broken.
This is more likely to happen if the height corrector cradle is partly seized, there are several topics on this site about such matters.
froggy
(Donor 2026)
x 4
are the front and rear "dog bone" link , clip identical ?
Terry
x 6954
Yes they are Terry, item 6 - same parts.
froggy
(Donor 2026)
x 4
thanks for the info.
Terry
