Reversing lights upgrade?
x 6956
Re: Reversing lights upgrade?
It may be more expensive if the right one has the LED drivers inside or additional control electronics. Beware there are 3 lots of light clusters - that look similar, but the others are not LED units. Breakers are also pretty clued up these days on parts prices, so if they have done their homework, don't expect to get one for a fiver! :-D They may well charge £200-300 if they know the cost of the originals....
WillyR
(Donor 2026)
x 5
Unread post by WillyR »
OK, your suggestion regarding the drivers etc sounds good. My car-breaker boy is usually OK, but rest assured I won't be paying more than £20-£30 or my investigation will grind to a premature halt.
Probably best to look for a damaged one. I only want to see how easily - or if - mine can be modified. :geek:
Will
2015 (Jul) C4 Grand Picasso 2.0 Bluehdi 150 EAT6 Exclusive+ now running on 17" wheels - SO MUCH MORE COMFORTABLE AND SMOOTH THAN 18" - AND better fuel economy :) =D>
citroenguy
(Donor 2021)
x 71
Unread post by citroenguy »
Here in dark Sweden it is pretty popular to put this sort of (https://www.ebay.co.uk/itm/48W-Super-Br ... 0obHQTkpTQ only an example there might be better ones) under the rear bumper/on tow bar.
I've also put upgraded led "bulbs" in my reversing lights works a treat.
I have various repair handbooks and wiring diagrams for C5 mk1, Xantia, XM, Berlingo and C3 mk1.
I have Lexia/Diagbox (Sweden) and Servicebox/sedre
x 6956
A supplementary light may be better - but his reversing lamps 'bulbs' can't be replaced - they are actual LEDS and part of a module.
You would have to be very careful with wiring anything into these later C4 Picasso (B78) vehicles that have a full CAN architecture, or it may have a detrimental affect on other systems. :wink:
Lenny
x 60
Unread post by Lenny »
citroenguy wrote: 09 Feb 2020, 08:36 Here in dark Sweden it is pretty popular to put this sort of (https://www.ebay.co.uk/itm/48W-Super-Br ... 0obHQTkpTQ only an example there might be better ones) under the rear bumper/on tow bar.
That's exactly what I've done, using the exact same lamp wired to the towbar electrics.
It's absolutely superb (although technically illegal in the UK as I've a total of three reversing lights).
