"Barn Find" 1982 or 83 CX D25
alfaholic_155
Re: "Barn Find" 1982 or 83 CX D25
Unread post by alfaholic_155 »
See the pics.
Engine code is M25/629
x 1240
Unread post by Peter.N. »
Well done Chris! 8-)
x 1751
Thanks for the numbers.
Details sent. Let's see what might come back.
Service.citroen (parts) not recognising that VIN, but not surprising as CX doesn't appear on the current system.
alfaholic_155
Chris;
Brilliant! Lets see what he comes back with!
Myglaren;
Thank you for editing, never know who might be looking I guess :)
General;
I will visit Kennedy Diesel tomorrow and see how the pump + injectors are coming along, also check the nearby wrecker to see whether they have a door panel laying around (my front right panel is cracked and taped). And lastly stop by a local workshop with two very friendly older fellas specializing in Hondas, perhaps they would know of a Citroen specialist in the area...
Other than that, I will start checking all the other "stuff" tomorrow, lights, hoses, interior switches and so on, just to make sure everything is in proper working order. Expect more pictures tomorrow. As for the brakes and suspension bits, I am afraid I would need the engine to be in proper running order... fingers crossed that the spheres are ok and all that would be needed is change of all fluids, engine oil, tranny fluid and LHM fluid...
I got two set of wheels for it, 14 inch steelies (without hub caps) and 14 inch alloys - I am planing on using the alloys for my trip home. The tires that are currently fitted to them, date back to 2008, they are rock hard, and dont hold air any longer, the size is 195/70, would that be the correct size to purchase?
The struggle shall go on... I will drive this sucker home, I am sure of it!
x 1438
Unread post by xantia_v6 »
Here is some info on CX tyre sizes: https://www.longstonetyres.co.uk/classi ... en/cx.html
alfaholic_155
xantia_v6;
That is a fantastic write up, however, it is a bit more expensive than what I am prepared to spend on this project, at this point in time..
I was looking at "normal" tyres, and as an affordable option I prefer Nexen HD blue for long motorway hauls, as it is a soft and reasonably quiet tyre..
Let me re-phrase my question; what normal tire size should I look for when purchasing a set?
Again, thank you for the link!! I might cash out once the car is back in Norway, as continue working on the car.
x 1751
Michelin Energy Saver Plus have proved a very worthy successor to Michelin MXV, Pilot and Primacy. Citroen suspension was designed around this type of Michelin tyre, with its very pliant sidewalls. If you can find the size, and an acceptable price, worth going for. Comfortable and quiet, and plenty of grip.
alfaholic_155
white exec;
Thank you for the tip,
What size should I go for with those Alloys I have ? And the original steelies?
x 1751
Sorry, I missed this post.
You're in luck with the Michelin Energy Savers for those 195/70R14 rims...
https://www.michelin.co.uk/auto/browse- ... 70/14/91/T
Load rating 91 = 615kg (axle weight)
Speed rating T = 118mph / 190km/h
You can use that same Michelin site to look at availability in other sizes, if needed.
On the timing front, Tom at SGG Dunsfold has come back by email this morning.
He's contacted a local CX expert, who should (should) have the timing data next week.
Hoping to send the pages to me.
Fingers crossed...
citroenguy
(Donor 2021)
x 75
Unread post by citroenguy »
Hello alfaholic
If you can take some Swedish i'd love to welcome you to the Swedish Citroën forum: https://citroenakuten.com/index.php
There are already some Norwegians there :)
You could see if you get some answers there too..
I have various repair handbooks and wiring diagrams for C5 mk1, Xantia, XM, Berlingo and C3 mk1.
I have Lexia/Diagbox (Sweden) and Servicebox/sedre
x 1751
Hi Taras,
Tom in the UK has come back with these Citroen pages this afternoon...
? Click to englarge
Let me know if that's the info you need, or any other pages. He's going to hang on to the booklet for a while longer before he hands it back to its owner.
Marc - I will tactfully ask later whether we could have shots of all pages for the forum library :wink:
x 1751
My contact in the UK only has this booklet in his possession for a brief while, then it must go back to its owner.
Have posted the pages here, sent Taras a PM, and an email, to ask whether this is all the info which is needed. NO REPLIES received!
