Ours is great - it's the 1.6 HDi Exclusive. Goes like SOAS, and round here in hilly Wales we get a tad under 60 MPG. Driving position / seats are slightly higher which is why we got it. In the nearly 13 years since we've had it, it's only covered 43k miles. The only things we've had done is a new dealer-fitted headlamp (water ingress), the alarm module (I did a write-up on that), and the front suspension springs and struts and a new comms unit. Just recently had the windscreen replaced at a large crack appeared from the corner and worked its way across the screen one day
Must of been a pothole although I do avoid those like the plaque where possible.
Incidentally they replaced it with the later athermic purple looking ones that are supposed to keep it cooler in bright sunlight - so didn't complain.
She's been faultless apart from that.
