C6 drivers window
dowen
C6 drivers window
Unread post by dowen »
Can anyone help! Drivers window stopped working, together with driver side fold away mirror.
So, replaced with Peugoet 407 window module. Now everything works! But of course I can't leave 407 module in as it doesn't have the facility to drop with the frameless door!
So, I've fitted a new c6 module, everything works, including mirrors, except pesky drivers door.
So with all this I've concluded the following : motors are all working. Mechanism free and lubricated.Window switches all good no bad connections, or high res faults!
Could the fault be in the BSI?
What puzzles me is the fact that the two C6 door modules (I know at least one is good)won't cooperate drivers window (but everything else).
When I fit Pug 407 module everything works!
Will Lexia show maybe disabled drivers window?
x 1056
Re: C6 drivers window
Unread post by wheeler »
Does the new unit maybe need programmed or initialised with Lexia/Diagbox??
dowen
Thanks, that's what I was wondering, but all other windows are OK! I'll see what Lexia comes up with!
x 6954
For clarification purposes, what specific 'modules' are you referring to? A part number will do.
dowen
Hi Mark, it's the module that's part of the window motor unit
x 6954
Ok, just comparing the parts and these are different for the 407 and the C6, but additionally, there was a change to the C6 left hand motor from build date 3rd March 2006 onwards. The Right hand one remained the same part number. But neither of these are the same parts as the 407.
