Hiya, i have a quick question that I haven't been able to find the answer to yet, I hope you can help
I'm looking at purchasing a 2010 C3 1.6 vti exclusive automatic for my partner. It's done about 75k, but before I go to view it etc, if like to know if it is a belt or a chain driven car?
And also what are the recommended intervals for getting these inspected/changed please?
I hope I get it but I don't want to buy it and find out that it should hedge been done and hasn't
Cheers!
C3 timing belt
- My Cars: 2009 (59) C3 1.6 16V Exclusive Auto (light blue)
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: C3 timing belt
No use with out a registration or VIN - there are different models with different engines so would need to know this basic info for a start.
EP6C and EP3C engines have timing chains
TU1AE5, DV4C, TU3AE5, TU3A, EB2, EB0, DV6TEDM, DV6C, DV6ATED4, DV4TD & DV6ETEDM engines have timing belts.
If you can pop up the reg or the VIN (auto masked) I will be able to confirm for you what it has.
Re: C3 timing belt
No problem, reg is ********
Reason: Masked Reg.
Reason: Masked Reg.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: C3 timing belt
Ok, so this is a C3 (A51) 5 DOOR SALOON 1.6 VTi 16v 120 (EP6C) 4-SPEED AUTOMATIC GEARBOX.
So this has a timing chain - they don't need replacing unless mechanically faulty. It also has the proper AL4 fully automatic gearbox, not the piloted manual, which if you wanted an Auto is a much better option.
Re: C3 timing belt
Perfect, thank you very much for the info! Yes my partner can only drive automatics, not a massive fan of them myself but hey ho lol
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: C3 timing belt
No worries - if it helps I can send you the full specs of the car through via email - let me know it.
Re: C3 timing belt
That would be great cheers, my email is
If you have it as well is there a guide or list of what should have been done on its services as well?
Reason: Email removed for security
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: C3 timing belt
I already have access to your email, so removed it from the public forum for your protection (spammers).
I can't tell you the service history as that will depend on where the car was serviced. If it has been fully Citroen serviced from new, then they will have a record of the services carried out, which they may be able to confirm for you. Obviously, if it has been serviced by a non-dealer, then there won't be any electronic records, but it may have some invoices of work done bundled in the documentation.
Re: C3 timing belt
Ah right ok lol, but yeah if you could send me the full specs of the car that would be brilliant for me to mull over then
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
