Ds5 fuel consumption
x 1240
Re: Ds5 fuel consumption
Unread post by Peter.N. »
It depends primarily on where and how you drive. I can get 70 mpg on the motorway from my C5 X7 estate, but then I am an old man and drive like one. :? 8-[
Michel
Unread post by Michel »
Over the years I've used many "premium" fuels and come to the conclusion they're all b0ll0cks. Not a single one has made any appreciable difference.
x 8167
Michel wrote: 11 Jan 2020, 18:55 Over the years I've used many "premium" fuels and come to the conclusion they're all b*****ks. Not a single one has made any appreciable difference.
All I would say is that the difference is most noticeable in terms of engine condition and oil cleanliness but it only happens gradually over a long period of consistent use. Using the odd tank here and there may well help with injector cleaning etc. as Marc finds but the real benefits only come to light with consistent use for 5000 miles plus.! :)
Michel
mickthemaverick wrote: 11 Jan 2020, 19:40
But how do we know? Do you strip your motors down after so long check?
It even states in my Yamaha MT-09 owners manual *not* to use premium fuels as the engine isn't mapped for them.
x 8167
Michel wrote: 11 Jan 2020, 20:08
I only know from the oil colour which definitely is much cleaner at oil changes than it used to be on leaded 4* and from the general lack of any form of engine faults occurring. I have never suffered valve issues or bigend wear for example in any of the cars, including a few very high mileage ones, since I have been using it. It is only personal experience which leads me to my conclusion and I would say that while the mpg is definitely improved, the mpp (miles per pound :) ) may be slightly reduced but I view that as the cost of better performance and smoother running. I'm certainly happy with it.
As regards your Yamaha then I would always follow the manufacturers advice and accept what they say about mapping. My RF900 runs very well on it as does the Deauville and they may have similar notes in the manuals which I have never read but I will have a look when I next go down to my man-cave :-D
Michel
mickthemaverick wrote: 11 Jan 2020, 20:25 I only know from the oil colour which definitely is much cleaner at oil changes than it used to be on leaded 4* and from the general lack of any form of engine faults occurring. I have never suffered valve issues or bigend wear for example in any of the cars
I should think that modern oils and tolerances have a lot to do with that, rather than the fuel - it's 21 years since leaded 4* was available for sale here and 27 years since one could buy a car without a catalytic converter.
I've never had any valve, big end, crank or engine issues in cars either. They were common in the late 70s and 80s British tat I worked on in summer holidays at a local garage though...
x 6950
I use the odd tank of premium diesel specifically for its fuel cleaners / engine cleaning additives. It's the fuel system I want to preserve and help prevent injector clogging. There's then no need for an additional fuel cleaning treatment if you regularly use a premium fuel. I'm not really bothered about any performance gains or extra MPG - as I never get anymore than 43MPG on the last 2 cars with similar engines and only slightly more than that on the 2.0 110 on the MK I C5.
x 8167
I take your point about modern oils and that may well be a contributer but tolerances no. My current cars are a nearly 20 and a 26 year old as have been the vast majority of my cars. In 2010ish when I started using premium fuel I was running a 1992 XJ40 and a 1984 Celica. The only car newer than 2001 I have ever owned was my 2007 Prius which was a company car (I owned the company) so my engines have generally been very old designs and hence the comparison to old 4* is valid.
An interesting test I saw at the classic motor show in Stoneleigh a couple of years ago showed a piece of blotting paper cut in half and one half soaked in standard shell and one half in VPower, both sourced from the local shell station. Both pieces were then put on an oven tray and ignited. After burning the standard fuel part had a thicker deposit than the Vpower side when the ashes were blown away. Read into that whatever you want but I was impressed!! :-D
AL-89
Unread post by AL-89 »
Hi everyone,
I own a Citroën DS5 2.0 HDi 165 Automatic (RHH / DW10CTED4), with approximately 269,000 km.
I’m experiencing unusually high fuel consumption:
* Around 13 L/100 km measured on winter using the full-tank method.
* Mostly short urban journeys, with an average speed of approximately 11–18 km/h.
Additional observations:
* The DPF has been disabled, but I don’t know whether it was removed physically or how it was disabled in the ECU.
* The car has a Stage 1 remap, but fuel consumption was already high before the remap.
* Occasionally, I hear a hissing/air-leak-like noise when accelerating.
* Sometimes an Engine Fault warning appears under hard acceleration, but the car doesn’t noticeably lose power.
* The engine temperature sometimes fluctuates between approximately 70 and 90°C.
I’d appreciate advice from anyone familiar with this engine.
PaulC5
x 717
Unread post by PaulC5 »
To help others, 13 L/100 km is 22 mpg.
What fuel consumption do you get on a long run as doing short trips will always give a poor fuel consumption ? Only averaging about 10 mph you must be mostly in first and second gear.
If the engine management light has been on then use a code reader to see what fault is stored.
x 1240
I have the 140hp version of this engine in my C5 estate but mine is manual and I don't do a lot of short journeys, are your journeys long enough for the engine to reach full working temperature? The 165 engine usually does a better consumption than the 140, in the C5 anyway.
A remap usually results in an improved consumption. The 'hissing' noise you hear could be a leak in the intercooler or the pipe between it and the turbo.
I suspect the variation in engine temperature is probably a faulty thermostat or the temperature sensor.
Part of the problem is undoubtedly due to it being auto, but the way its being driven also has a lot to do with it. I'm old so I don't drive very fast or furious. My car averages the mid 40s as a yearly average but in the summer on the motorway 60 mpg on the motorway is easily attainable and I always average that on my yearly trips to the north of Scotland. I have had a number of C5s and they all return those sort of figures, but they were all manual.
I have found though that the first few miles of a cold journey do result in a considerably higher fuel consumption, possibly not much over 30 but it it rapidly improves as the engine warms up.
To sum up, to cold and to fast are the most likely causes. Do you get any black smoke from the exhaust?
AL-89
Thanks both for your replies!
Regarding your questions:
* Long journeys: My fuel consumption is around 7–7.5 L/100 km on open roads.
* Engine temperature: My usual morning journey is only around 5 km in 30 minutes due to heavy traffic. In colder weather, it takes 30–40 minutes or sometimes longer to reach 90°C.
* Black smoke: No, I haven’t noticed any black smoke from the exhaust.
The hissing noise is intermittent — sometimes I hear it during acceleration, sometimes not.
I’ll arrange a diagnostic scan to check for stored engine fault codes.
Could the thermostat be contributing to the high city fuel consumption? And could a boost leak from the intercooler or turbo pipes also affect fuel economy?
PaulC5
x 717
7-7.5 l/100 km is about 38 to 40 mpg so seems low.
If you use a code reader with live data see what temperature the radiator top hose starts to get warm as the engine warms up from cold. This will be when the thermostat begins to open. You can find out what this should be by looking at somewhere like autodoc for the correct one for your car but could be about 90°C. If it opens lower then the thermostat could do with being replaced. If opening too early or always being open, you might also find the cabin heater is not that hot.
Cupra to DS5
x 5
Unread post by Cupra to DS5 »
Stumbled across this thread and it made me think.
I vary between 37 - 45 mpg on average but mixed driving. Been happy with that as came to this car from a Leon Cupra R..... 🤣🤣🤣
Mine is the 2.0 hdi 163 hp
windy1603
x 17
Unread post by windy1603 »
My old DS5 163 Manual 18" wheels (Now owned by my son) still returns around 50 mpg in normal driving, even with a 195 BHP remap. My son-in-law has a DS4 with the same engine and remap, and it returns similar MPG.
Calculated from brim to brim filling, which was nearly identical to Trip Computer (Injector calibration table not tweaked during the remap, which often screws up trip MPG)
