Parasitic drain
colin machin
Parasitic drain
Unread post by colin machin »
Hi. I have a 2007 Citroen C5 2.2 hdi. I have a parasitic drain which is draing the battery over night. I have checked the inside fuse box, and the 10 AMP fuse on the top row next to the HS fuse, when the car is put to sleep it registers 45 milliamps, does anybody know what the 10amp fuse supplies or have the wiring diagram for this?
Any help would be greatly appreciated.
C5 2007 HDI
x 6954
Re: Parasitic drain
Which fuse box? - There are several in the engine bay and several attached to the BSI.
The fuses are marked - 10A won't help much - we need the fuse number which is clearly marked next to the fuse on the box if you shine a light on it.
Also pop your VIN up for the C5 - the fuses can vary depending on model.
x 1480
Re: Parasitic drain
45mA is only 0.45Ah over 10 hours - that's not enough to drain the battery. A 2007 will shut everything down after a few minutes when the BSI goes to sleep - so unless some aftermarket kit has been added, then it's unlikely to be a power drain problem - more likely the battery is shot. You need a drain of 2-3 amps to flatten a healthy battery overnight.
x 1438
Re: Parasitic drain
Unread post by xantia_v6 »
Yes, 45mA is probably within the normal range for modern vehicles, Are you sure that your battery has not expired?
x 1751
Re: Parasitic drain
Do the check on parasitic drain at a main battery terminal, if that is possible.
Agree with the above; drain on XM (for example) is approx 32mA max, which is harmless.
colin machin
Re: Parasitic drain
hi i have put the multi meter in line with the battery and the reading is a drain of 0.02 .i will have to start pulling fuses
C5 2007 HDI
x 6954
Re: Parasitic drain
Also don't forget that depending on what Head Unit you have (we still don't have your VIN so can't tell) this may continue to operate after the vehicle is locked for some time (internal cooling fan for example). You'll also have to wait a good 10 minutes or so to check the drain to allow the BSI and other ECUs to complete their data writing and allow the networks to sleep. Also if you need a door open, you will have to flick the door lock latch shut to fool the BSI into thinking the door is closed or the RCD circuit will be live (waking of the data networks / suspension levelling) etc.
x 1751
Re: Parasitic drain
0.02A (20mA) is a quite acceptable quiescent battery drain.
You probably won't be able to reduce that figure much, without disconnecting things.
Pulling fuses is the right way to diagnose, though.
Battery might be self-discharging, with age.
moizeau
x 429
Re: Parasitic drain
Unread post by moizeau »
In the time it normally takes to discharge, disconnect the battery for the same period of time. Reconnect (observing the battery reconnect procedure) and see if it's OK or as before. Easiest way to check the battery condition in a discharge scenario without specific tools.
Pete
colin machin
Re: Parasitic drain
hi at the moment the battery is holding its charge it is a new battery .the battery drain is 0.o2 at the moment and i know it sounds daft but i only drains over night when its be low freezing .i will after wait ti the temps drops and test it when its freezing .any suggestions welcome
C5 2007 HDI
x 6954
Re: Parasitic drain
Don't forget your alarm, which, depending on option (again I can't be specific without your VIN), may include the volumetric sensors in the cabin. The system is also monitoring and waiting for a remote unlock wake up request, and if you have TPMS installed, these also poll regularly.
x 1056
Re: Parasitic drain
Unread post by wheeler »
0.02 amps is well within spec. On a mk 1 C5 a top spec model should only draw around 0.06 amps.
Can your meter record max & min ? might be worth leaving it on for a few hours & see if something is waking it up as the 0.02 amps is not your problem.
JonRRolyat
Re: Parasitic drain
Unread post by JonRRolyat »
Hi Wheeler , did you get anywhere with this? I have an identical problem but it tends to happen only in the wet.
C5 1.6TDI 2006
x 1056
Re: Parasitic drain
JonRRolyat wrote: 31 Jul 2023, 08:04 Hi Wheeler , did you get anywhere with this? I have an identical problem but it tends to happen only in the wet.
C5 1.6TDI 2006
It wasn't me having the issue I'm afraid. Have you measured the Amp draw from your battery?
Do you have any non original electrical equipment fitted to the car eg handsfree kit, reversing sensors, different radio?
x 1054
Re: Parasitic drain
Unread post by Rp0thejester »
Parasitic Drain....have you both bumped into my wife??
