auxcillary belt replacment
froggy
- (Donor 2026)
- x 4
Hi, just been trying to fit a new auxcillary belt to my S1 Xantia, Iam struggling ! is there a right way or wrong way, I have loosend the pulley in the middle but can not get it over the bottom pulley. new belt is the same sixe as the old one, any help greatfully received, thanks in advance Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
froggy
- (Donor 2026)
- x 4
Re: auxcillary belt replacment
just wondering..... the belt has 1130 stamped on it, the same as the old one. maybe the old one was the wrong belt ? anyone know what the correct size should be or number on the belt ? cheers Terry.
Terry
lexi
- x 134
Is there spring tension to be backed off? I have done this belt but forget the details now.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
froggy
- (Donor 2026)
- x 4
no its manual
Terry
- x 6961
1130 K6 is the original (Citroen part: 5750TK or 1606351180 for the non OEM version).froggy wrote: 28 Dec 2019, 17:37 just wondering..... the belt has 1130 stamped on it, the same as the old one. maybe the old one was the wrong belt ? anyone know what the correct size should be or number on the belt ? cheers Terry.
froggy
- (Donor 2026)
- x 4
cheers
Terry
Pug_XUD_KeenAmateur
- (Donor 2018)
- x 228
I'm not familiar with the set up on the Xantia, but its possible that there's more than one way of adjusting the tension on the belt. In some cases there's a Tensioner that can be moved and, in addition to that; the Alternator can be loosened and pushed one way or t'other to create extra slack.
Make sure you get a photo or sketch of the routing, particularly if its a complex one with AC and PAS, coz its easy to forget once its off and spend 'forever' trying to get the thing back on coz you're doing it wrong
Puxa
doctle
- x 226
