Fuel additive level too low error
x 6946
Re: Fuel additive level too low error
jckm2000 wrote: 14 Dec 2019, 13:26 Hi Folks,
I've recently bought a 207 1.4 hdi and the 'anti-polution' error has just come up.
I can't find the DPF bag/tank on my car, it's certainly not where it's pictured above. There's nothing running alongside the exhaust heat shield.
Any idea where I can find it?
Vin no. VF3**************[VIN obfuscated, can be read by forum staff]
Cheers,
Jon
Hi Jon, there's a very good reason why you can't find the DPF - it doesn't have one on this engine :-D So obviously no additive tank.
The anti pollution error can be down to several reasons in this case - an EGR blockage or even a lambda sensor or air problem. Your best bet though is to get a diagnostic done with Diagbox as this is a 2010 model. That should provide one or more codes and that may point you in the right direction. Absolutely no point in randomly replacing parts in the hope it will cure it. Any imbalance in the air or fuel system can possibly trigger a fault, so best to get a diagnostic first.
jckm2000
Unread post by jckm2000 »
Blimey! Lol, anyone in the Norwich area that can read my codes for a free bottle of PAT fluid?? ;)
x 5674
Have a look here
Map at the bottom (click the link) to see who is nearest, then PM them to arrange session.
Note that members are not available all the time and some have gone dormant so you may need to try a few. From the member list you can see when they last logged in to the forum.
jckm2000
Thanks very much! 🤗
skipper79
New User
Unread post by skipper79 »
hi All
I have same problem
just bought Peugeot 207 and warning massage - Fuel additive level too low- appeared
my VIN is VF3**************[VIN obfuscated, can be read by forum staff]
what type of additive should I buy
many thanks in advance for all answers
x 6946
skipper79 wrote: 30 Sep 2020, 18:56 what type of additive should I buy
You need 'Powerflex' Additive for your additive tank.
Ajhannington
New User
Unread post by Ajhannington »
Were is the fuel additive tank on my Peugeot 307 1.6 HDi
x 6946
There are generally next to the fuel tank, on the rear left hand side, under the heat shield / protection covers.
Wingphil
Unread post by Wingphil »
Hi
I joined a few months ago, having got a 208, I have not been too active on the site as I have mostly used when I have issues- which seem to be common.
Anyway today I got this DPD fluid issue, and am going to need to sort some diagnostic kit out for the reset- after a bit of under vehicle crawling...
Unfortunatly when I tried to pm, my inactivity is blocking me. I was thinking of utilising givemeabreak’s recommendation get the discount and go to his recommended site.
So if he reads this can he tell me if I am eligible for the discount?
Incidentally if anyone foes have a list of devices that can reset this issue I would love to here/see it.
x 6946
You can't PM anyone until your first post - which is what you have now done. So the PM system will work for you from now on.
The additive counter will need resetting using a suitable and capable diagnostic tool. You'll also need a laptop. If you are intending to diagnose PSA vehicles earlier that 2017 ish, then the kit with DB7 may be for you. If it's a one-off operation, then it won't be very cost effective and you may be able to contact a member here with a kit to help. Failing that a dealer will charge you diagnostic time - anything from half an hour to an hour, so about £90 for a diagnostic.
ElioFernandes
Unread post by ElioFernandes »
Hi mark. My VIN IS VF3**************[VIN obfuscated, can be read by forum staff]. please i would like to know which brand i should buy. thanks
x 6946
@ ElioFernandes: You would need Powerflex for your later 308 (T9) vehicle with build date 13969
ElioFernandes
Been checking and i found power flex 1,2,3, and 4. Which on its is? 😆 Im confused, is it number 4?. Thanks
x 6946
Powerflex is Powerflex! Are you sure you are not mistaking the other numbers for the container sizes?
3 Lt kit here:
https://www.ebay.co.uk/itm/332964327704 ... Sw7OdcGicH
ElioFernandes
Apparently there is powerflex for 1,2,3,4 generation dpf. My one should be 4th
