Hi Guys
Is there anyone that could help out with a set of electrical drawings for the 2005 Xsara Picasso 2.0 HDI
Vin No VF7**************[VIN obfuscated, can be read by forum staff] .
2005 XSARA PICASSO 2/0 HDI Wiring
- x 6963
Re: 2005 XSARA PICASSO 2/0 HDI Wiring
We don't supply wiring diagrams sets - but we might be able to put up a specific one or two here to help with a particular issue only.
Anto
Hi Marc
The drawing that I need is for the exterior lighting and signalling . At present if you select the right signal ,it flash twice and the lights switch on and the right signal stops flashing .If the park lights or headlights are switched on manually then the right signal works perfectly .I am also looking for a drawing of PSF1 particular the 16V VE Socket .
Thanks Ant
Thanks Ant
- x 6963
Leave it with me and I’ll see what I have.
- x 6963
Bear in mind that you have a CAN VAN system with BSI COMMS 2000 slave unit.Often the Comms unit inside the steering wheel can cause intermittent faults with signalling and lighting. The signalling (indicators) are controlled by the BSI - not the engine fusebox, which would also follow with what I've said about the Comms 2000 unit.
Here you go - these are high quality SVG vector files so will scale perfectly regardless of device.
Signalling
PSF1 Engine Fusebox A
PSF1 Engine Fusebox B
Signalling
Anto
Thanks for the Help Marc
Regards
Ant
Regards
Ant
