RD45 questions + Microphone installation C5 X7 + Amplifier installation
- x 6945
Re: RD45 questions + Microphone installation C5 X7 + Amplifier installation
It looks ok - but I simply can't tell you from here - I think as long as the software version is at least V.70 or higher = which others have said works for them.
Slobo2712
Display has arrived and everything is working well.Now im interested how to connect microphone,I have mic in car from old kit it has 3 seperate wires.This is how its look from rear side(aux is connected).
- x 6945
Good news on the screen then
Ok, so for the standard Mic (which says not fitted in your 307 as standard kit), this is the RD45 pin-out for the MIC. I've used your picture and circled the correct block - channels are below:
"ac" Natural 12-way connector
| Channel number | Allocation of channels of connector |
| 1 | Channel not connected |
| 2 | Channel not connected |
| 3 | Audio/telephone microphone earth input |
| 4 | Right-hand audio auxiliary |
| 5 | Channel not connected |
| 6 | Channel not connected |
| 7 | Channel not connected |
| 8 | Channel not connected |
| 9 | Audio/telephone microphone signal positive input |
| 10 | Left-hand audio auxiliary |
| 11 | Audio earth |
| 12 | Channel not connected |
Slobo2712
Thank you very much.I have connected mic as that instructions everything is working good but other person hear it self when talking,I havr tested viber call..
Ps. Why usb songs list are always the same,no matter which first letter of artist is,how it is sorted by name or what?
- x 6945
Great, glad you have it sorted - almost!
Make sure you have the CDTEXT option activated / enabled in Lexia - it should be in the Head Unit Menu somewhere. Also make sure you have allowed the correct permissions in your phone menu. Lastly, I'm not sure if this unit supports 'Playlists', but it may take some time to build into memory the files. Try making an MP3 CD (only burn at maximum 4 x speed - no more and use Joliet to close the CD and see if that also works.
As for the microphone, is it an original PSA one or an aftermarket one?
Slobo2712
- x 1463
Perhaps your microphone is too sensitive or in the wrong place for the echo-canceller in the RD45 to work well?
I think that the car user manual has some information on file naming for MP3 files on CD/USB to allow some folder structure (I don't remember the details).
- x 6945
That MIC may not have noise cancelling features - which is why I asked, so may be the cause of the issue.
