- x 2000
Re: I am an Activaist-v6 and suffer AX-isum
Maybe....but this has been on the car for 3+ years
- x 2000
All done, how the pump and the main HP pipes survived this I do not know....I hate not having time to check my cars constantly !!!!!!
The car started being like all our politicians, (fecking about and being resistant to my wishes etc) so I punched it in the face !
OnlineHell Razor5543
- x 3306
Ouch!!
Reason: Removed superfluous quote (previous post)
- x 2000
Well I did not need them but at £102 for this full set (using twin offers) which will be replaced FoC for ANY reason for LIFE I really could not say no !
Halfords Advanced 200 piece in Anodised Matt Black
- x 2000
Ahhhhhhhhhhh, sad to see her go, but the new home is local and is looking forward to improving her care some more.
Bye bye Daffodil, you smashing little car !
- x 2000
Re: I am an Activaist-v6 and a 2.1err
A little bit of 2.1td work is required
Some little bits to weld.....BUT
This has been caused by a hit to the arch at some point, NO rust protection was done on the inside face of the wing it is not the "normal" wing rot.
The areas inside the boot/inner wing are all clear and the sealant line is good, not swelling at the door shut area either.
A small patch on the sill from a damaged Sill-end plug also needs a patch.....all on the lower edge of the sill from water/Mud build up....about the size of a fag packet.
- x 8368
Re: I am an Activaist-v6 and a 2.1Estateerr
^^^ I do like these ventilated wheelarches
They are very aerodynamic and worth a good 20BHP
- x 1452
They are well on the way to being the QR code for this forum..
- x 8368
- x 2000
ohh, I like a French Filly
- x 2000
When in a hole stop digging ?
Time to start using the V6 Activa donor car !
- x 8368
Oh dear, that's a bit frilly!!!
- x 2000
A body-shop had overpainted with seam sealer then top coated with stone chip
The Sill-end bung had been filled with silicon the revived seam sealer and a coat of underseal.
I HATE bodgers, shoot the bastards !
Anyway, as said I have the parts and it does not make the job much bigger to replace a small piece/large piece.
- x 2000
Finished digging, got to the clean stuff...the is more rust up my nose and down the back of my neck than the car now ! (What is left is just surface so will get to that later and use rust converter, S90 cavity wax/rust inhibitor from Bilt&Hamber will cope with what is left.
Time to start cutting the part from the Latvian V6.
- x 8368
That's a beautifully tidy bit of work Alasdair
Hope the Latvian doesn't look like Chantilly lace too
