Hi
Does anyone know where to find the engine oil level sensor?
I have recently changed oil and my car is showing 'check engine oil level' and 'engine oil level incorrect'.
I put 4,25l in as it is stated in the book, so I am clueless.
C5 2010 1,6 THP aut. deceleration noise
- x 1459
Re: C5 2010 1,6 THP aut. deceleration noise
Have you checked the level using the dipstick?
The warnings that you are seeing are probably because the oil level is too high.
- x 6945
Item 15 should be the engine oil level and temperature sensor which is at the back of the engine. But as Mike says - always check using dipstick in level ground.
mf.lorant
Hi
Solved the issue, changed the oil, now everything is fine.
Other
Each and every morning I do have a little oil stain on the ground under the car, do you know anyonown or common oil leak places on this engine where I should start searching?
Other
- x 1459
It is fairly common for them to leak a little around the edges of the engine top cover, but you will need to do your own investigation.
mf.lorant
Andnyes, it is leaking around the edges. Is this top cover leak serious or I can leave it as it is?
