x 3296
"This modification is a safety feature for pedestrians. The propeller is running in reverse when the car is at a low speed, so if a pedestrian steps out into the road without checking first the wind generated by the fan should blow them out of the way before my car hits them".
x 8126
Hell Razor5543 wrote: 03 Oct 2019, 21:50 "This modification is a safety feature for pedestrians. The propeller is running in reverse when the car is at a low speed, so if a pedestrian steps out into the road without checking first the wind generated by the fan should blow them out of the way before my car hits them".
And of course that enhances the cars braking ability and thus reduces the insurance premiums. Not many cars around with auxiliary air brakes other than my pet Bloodhound!
x 5673
Comes up as a Cougar,
MOT expired
SORNed.
x 8126
I just DDG'd Cougar and was a little surprised at the result. Are you sure that you don't mean "Porned" :-D
x 3296
"Meanwhile, once I am at motorway speeds the propeller is allowed to turn with the wind (as opposed to against it at low speeds), and because of the design of the motor used, when it is being turned by the propeller it generates electricity (meaning it is now a wind turbine) which is then fed into the auxiliary batteries I have fitted, to recharge them (oh, did I mention I have converted the Ford Cougar into a hybrid?), so making the car into one of the 'greenest' on the roads".
x 8126
Excellent work James, but are you sure there are no grey areas? :)
x 3296
mickthemaverick wrote: 03 Oct 2019, 22:09 Excellent work James, but are you sure there are no grey areas? :)
Lots, in that camouflage paint!
x 8126
An unsolicited offering for the nature club, dread to think how much his shoes would cost!!:
Found in Mallorca, own work
x 7165
^^^^ Even more dangerous than leaves on the line our little many legged friends.
https://www.businessinsider.com/giant-m ... ?r=US&IR=T
x 7165
Can I gently entertain and amuse with this little bit of trivia
What do the cars in the picture have in common.
screenshot
screenshot
Not much of a headscratcher but the story is in the spoiler
Spoiler: show
http://www.oldclassiccar.co.uk/fab-1.htm
x 8126
What I want to know is: If both disabled people are at home do they close the road?
own work
own work
x 5673
That reminds me of some of these stair designs
x 8126
I can believe architects would design some of those examples - I just can't believe chippy's/brickies/fitters would build them!! :-D
Zelandeth
x 1604
Unread post by Zelandeth »
My guess would be that there used to be a door there which has since been blocked off... removing the stairs would be expensive!
Current fleet:
x 7165
On a staircases theme, there are some quite magnificent ones in this gallery from National Greographic
https://www.nationalgeographic.co.uk/tr ... hot-stairs
and here is the famous impossible one
Impossible staircase
Sakurambo [Public domain], via Wikimedia Commons
