COMPLETED - Forum maintenance 06/10/2019
Forum News, Announcements and any issues you're having with the forum
x 1481
Unread post by xantia_v6 »
I need to reconfigure the server to use more current maintenance streams of some of the software applications.
This may take a couple of hours. I will attempt to do this tomorrow morning.
[Edited to change date]
x 1481
Re: CANCELLED!! Forum maintenance 04/10/2019
I have to indefinitely postpone the server upgrades, as they appear to require an update to the wiki software, but the currently released version of that has a bug which prevents it working on our server and I need to wait for the patch release...
Sometimes it can take months to get compatible versions of all of the software packages all available (and installable) at the same time.
x 1481
Re: Forum maintenance 06/10/2019
I have now got around the mediawiki software compatibility issue by installing the LTS version of that software, which seems to be working correctly with the current server configuration.
So I will attempt the server upgrade on Sunday morning.
x 1481
Re: COMPLETED - Forum maintenance 06/10/2019
I have upgraded the database server package to the current maintenance stream, this may have a small positive effect on performance.
I had intended to also upgrade the php maintenance stream, but have decided to hold that until the next major phpBB upgrade.
As usual, shout if you notice any new issues.
