C5 X7 Radiator burst
x 6962
Re: C5 X7 Radiator burst
16 is the bonnet lock. The radiator is fitted on elastic dowels (2), so is designed to be firm but slightly pliable - but not enough to move it like you describe.
x 1751
There should be very little movement of the radiator - perhaps just a couple of mm, against the rubber bushes.
x 3567
When I checked mine yesterday, the push-fit location lug at 4 (above) was slightly out of its socket. Nothing drastic, but it just wasn't sitting where it was designed to go and didn't seem to want to sit snugly.
Kennyd90
x 5
Unread post by Kennyd90 »
I think your radiator is a freak accident. I have had a look at mine. And there are no screws that could cause this situation.
Doxat
x 3
Unread post by Doxat »
I do not know... visit it today... and new radiator is now on... tests in course...(photo made before)
But, in the bay, there is one confusing tube, (also for "expert")... it is unattached on one side, and we do not know for what it is, and where should go..
Can somebody give some idea... it is tube next to the battery, after ribbed one... tin black hose, with yellow ring some ?0cm from end of tube (look at photo). Other end enters black box on top of engine, were injectors are...but where should other go!?
Doxat
x 3
I took the car 20 min before... 10 I'm city ride,.. temp 97'C - fan kicks in - 95'C still working... looks normal, just when I parked, sow some wapor going little bit around lights... open the hood, but I think it is vaporising humidity from antifreeze spiled all over bay... will see tomorrow.
Conclusion from service is that there is nothing wrong... everything working fine, no explanation for radiator burst... just happene?...
Doxat
x 3
Can somebody identify this hose? From and where should go... ? It starts under black cover (top arrow), and ends unattached...
tnx
x 6962
I am trying to identify it - and so far the only thing I can see vaguely near the top cable is the injector harness:
Doxat
x 3
car is working normally... today city ride... temp never rised over 80'C ... no errors... but this hose rimaned under unatached... and now worm is biting me what should it be...Auto industry don't waste hoses just for fun...
Doxat
x 3
GiveMeABreak wrote: 04 Sep 2019, 16:45 I am trying to identify it - and so far the only thing I can see vaguely near the top cable is the injector harness:
As I can see here are only cables... this was rubber hose some 3-5mm inner diam (luce vacuumm ones)... no idea still... Should I try to dismantle everything to see were it starts?
x 1751
Yes, what you have is a pipe, not a wiring/harness.
See whether you can identify exactly where the pipe leads to on the engine block.
