guys
i have bought an aux cable and connected it to the back of the radio.
it didn't work apparently i have to use the obd port and menu selection cd & aux 1 to enable the aux.
I was looking for a obd2 cable to usb and get hold of diagbox to do it.
But i just messaged this guy https://www.ebay.co.uk/itm/122026499846?ul_noapp=true
and he told me that this won't work with diagbox.
Anybody know which cable or software i will need.
cheers
citroen c8 blaupunkt rd4 radio aux input
Moderator: GiveMeABreak
- My Cars: citroen c8 2.0 hdi
citroen zxara picasso 2.0 hdi
citroen synergie 2.0 hdi (another)
citroen synergie 2.0 hdi (lemon sold for scrap)
citroen zx 1.9TD
volvo v70 2.5 tdi estate 1998
volvo 940 2.0
austin montego (lemon gave away after spending £££)
rover 214s
nissan serena mpv 2.0 D (wrote off) - x 6
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: citroen c8 blaupunkt rd4 radio aux input
You’ve got it all mixed up by the sounds of it.
Basically what you need to do is enable the CD Changer port on the Head Unit. This was for the optional CD Changer.
To do that you will need to get somebody with a Lexia or Diagbox diagnostic kit to enable this for you as the Head Unit ECU has to have the CD Changer parameter enabled.
There’s no such thing as an OBD to USB cable.
The OBD port is what the diagnostic kit uses to talk to the car in order to change the option above.
Remember the CD port can only mimic functions of a CD Changer.
citroen zx 1.9TD
volvo 940 2.0
rover 214s
thanks for the response Marc
this is what I'm trying to do
I was under the impression that i could get a cable that plugs from the obd2 port to USB on the laptop and run diagbox/lexia on that ?
I have that CD changer cable plugged in now just want to do the other part ?
Reason: YouTube link
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Yes, got, that, but these are 2 separate things. You can do the first part, but you need a laptop, diagnostics kit and the software and the knowledge to be able to change the setting.
Have a look at the Lexia owners on this site to see if there is somebody who will enable the option for you:
https://www.frenchcarforum.co.uk/forum/ ... hp?t=56452
There is a map at the end of the post showing the member locations on a Google map.
citroen zx 1.9TD
volvo 940 2.0
rover 214s
cheers Marc
that's very helpful indeed there is a guy fairly close to me i'll msg him
best regards
best regards
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, just remember not all members are active on the Forum all the time, but fingers crossed.
The option will be in the Head Unit RD4 ECU.
