Hi all.
I am about to look over a few Citroen ZX's for a friend who wants a new diesel motah. She wanted a Pug 306, but these are out of her price range (max £500). So I recommended a ZX instead, being every bit as good-a-car as a 306.
I have looked over and bought dozens of cars in the past, but I was wondering if ther is anything ZX specific that I should be looking for, as I've only ever driven one before, never worked on one.
Muchos grassy-ass for any advice given.
David.
What to check on a ZX
wilkobob
Only things I can think of are... Check that the Head Gasket hasn't gone, the cam belts been replaced, and that the wheels at the rear dont sit / \. Other things to check are that all the central locking (including the boot) work, and that the electric and manual windows go up and down.
Only other things are the cords on the parcel shelf, and the rear wiper.
Cant say ive noticed anything else that seems to go wrong on all of the ZX's ive seen! Good Luck
IAN.D
rashmore
arry_b
Also look out for:
Dash bulbs (blown - painful to replace)
Wobbly speedo (cable - painful to replace)
Sticking front calipers (normal PSA rubbish)
Caliper bleed nipples (seized or sheared off)
Rust in the horizontal sections behind the rear wheels (underseal lifts)
Centre pipe to exhaust tailbox joint (exposed to road salt - rots)
Rear subframe mounts (knocks from rear - long horrible job)
Poor handbrake (cables or self adjusters)
Near me £500 doesn't buy much reasonable ZX Diesel, at least not one that doesn't have some fairly major work looming. Would she not consider the 1.4 petrol, as they go for less?
- x 1431
Have a look at the brake back plates and see if the wheel cylinders have been replaced. They start leaking over 100k miles and the rear brakes need rebuilding. I have just done this on ours, and it cost nearly £200 in parts alone - would make a £500 car uneconomic if you were paying someone else to do it!
arry_b
Stuart McB
- x 1431
fastandfurryous
- x 4
Well, first one was a disaster. I think it had just about every problem going:
Blown head gasket (like REALLY bad. Spat coolant out past the done-up rad cap!)
Rusting in the seams (it was near the sea),
Knackered belt tensioner,
Badly fitted cambelt (not a single clip on the belt covers!),
Wonky rear wheels,
Duff battery..... The list goes on.
The only thing in it's favour was 11 months ticket, and a new rad. I offered him £50 for it. He told me it was at least £150 or bugger off. I chose the latter option.
The bit that makes me laugh is that it was advertised as good condition, with slight starting problem [:o]
on to the next one........
Wonky rear wheels,
Kowalski
James.UK
fastandfurryous
- x 4
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by James.UK</i>
Make sure it has power steering! I have come across two that didn't, and they would be impossible for a girl to drive..
Normally I'd agree, but in this case, no. Said girl also drives a 1975 10 tonne GVW Bedford TK horsebox without power assistance.
Next possibility is a pug 309. They're ULTRA cheap!
dillosk8ter
Mechanically 309 diesels seem pretty tough. My dads had a '93 Style D 5dr for 5 years now and it takes one hell of a hammering, driven across fields, carting allsorts of crap about and covers alot of miles each year and never gets serviced....drove it other day for first time in over a year..decent handling, space and ride. Shame there so unattractive, although this makes them a perfect bargain workhorse. Paints a bit crappy also. Have to keep more of an eye out for rust than on a ZX too.
