C5 Eolys Question.
x 3300
Re: C5 Eolys Question.
Bobins, that makes a lot of sense.
x 6955
Yes, because if the wrong types are mixed, it causes the whole additive system to become blocked and the injection pump will seize necessitating very expensive repairs. Better to use the correct type only - White, Green or Blue exclusively based on the RPO and clickfit connector cross references.
It might be wise to update that previous post of yours Robin - I do change out of date info where I see it to prevent confusion wherever possible. If you can't edit the post now - let me know and I'll do it for you. :)
x 3566
GiveMeABreak wrote: 15 Aug 2019, 14:52
Updated both the original post from 5 years ago and the post from yesterday with new info.
x 6955
Sound job, thanks Robin.
