Hi All,
On my drive to France last week the engine management came on, this happened when accelerating away from the toll gates. There was obvious loss of power or anything else but the cruise control and A/C was not working.
Once back home my laptop for diagbox played up but I eventually got the following codes
P1445 Additive adding ---- The quantity of additive injected into PEF has exceeded the max threshold. PEF must changed.
along with P1496, P1497 P149C Variable resistance turbocharger
P0234 Charge Pressure regulation
I suspect they are related.
Kenny
c5 x7 fault codes
KennyW
- x 165
c5 x7 fault codes
C3 1.4 petrol (SWMBO)
- x 6945
Re: c5 x7 fault codes
Hi Kenny I can't locate your VIN, so if you can provide that I can look into the specific codes for your engine.
KennyW
- x 165
Marc,
VIN is VF7**************[VIN obfuscated, can be read by forum staff]
- x 6945
Ok, so basically P1445 is telling you that the filter is at the limits of the unburned Cerine that remains in the particle filter.
Additive injected into the fuel system over time to lower the combustion temperature for burning of the particulate matter has a downside. It contains Cerine which contains elements that cannot be burned off and these remain in the particle filter, leading to its eventual blockage. The engine ECU records the amount of additive injected since the car left the factory (and whenever you refill it when resetting the additive counter to zero). This is recorded in grammes. A weight - to mileage table is used to estimate the amount of Cerine dumped into the filter based on distance travelled. So you have probably reached the upper limit. How many miles have you done?
Here are the faults codes and likely suspects:
| Fault code | P1496 |
| After sales description of the fault code | Variable geometry turbocharger : Position incorrect in relation to the requirement (Too much turbocharging pressure) |
| Description of the diagnostics | The position measured is less than the reference by more than 30 % for 5 seconds |
| Conditions of activation of the diagnostics | Engine has been running for at least 6 s |
| Conditions of disappearance of the fault | Driving with the engine hot for 5 minutes |
| Down-grade modes if fault present | - |
| Switching on of the warning lamp and/or warning message | - |
| Main customer complaints likely | Noise Diesel fuel consumption a bit higher |
| Suspect areas | Turbocharger: Variable geometry closed Turbocharger solenoid valve: Failure of the solenoid valve; Electrical harness Position indicator of the turbocharger: Electrical harness Vacuum circuit: Blockage |
| Fault code | P1497 |
| After sales description of the fault code | Variable geometry turbocharger : Position incorrect in relation to the requirement - Not enough turbocharging |
| Description of the diagnostics | The position measured is greater than the reference by more than 30 % for 6 seconds |
| Main customer complaints likely | Noise Smoke from the exhaust Lack of power Loss of braking |
| Suspect areas | turbocharger: Variable geometry open Turbocharger solenoid valve: Failure of the solenoid valve; Electrical harness Position indicator of the turbocharger: Electrical harness Vacuum circuit leak |
| Fault code | P149C |
| After sales description of the fault code | Variable geometry turbocharger : Excessive drift on the last initialisations of the lower limit |
| Description of the diagnostics | Drift of less than -0,5 V or more than 0,5 V in the initialisation of the lower limit of the variable geometry of the turbocharger relative to the first initialisation |
| Drift of less than -0,3 V or more than 0,3 V in the initialisation of the lower limit of the variable geometry of the turbocharger relative to the last initialisation the previous time the network went to sleep (Power latch) | |
| The fault immediately appears | |
| Conditions of activation of the diagnostics | Immediately following the initialisation of the lower limit |
| Conditions of disappearance of the fault | 3 successive starts, allowing time for the network to go to sleep (Power latch) |
| Main customer complaints likely | Noise Diesel fuel consumption a bit higher Lack of power |
| Suspect areas | The variable geometry of the turbocharger is locked Turbocharger solenoid valve: Failure of the solenoid valve; Electrical harness Position indicator of the turbocharger: Electrical harness Vacuum circuit |
| Fault code | P0234 |
| After sales description of the fault code | Boost pressure regulation: Air pressure above the reference value |
| Description of the diagnostics | Engine speed between 2000 and 3000 rpm - Engine torque below 300 N.m |
| The measured turbocharged air pressure is 450 mbar above the reference value (For 6 seconds) | |
| Conditions of activation of the diagnostics | The following conditions have to be met - Engine speed above 1500 rpm - The actual engine torque is higher than 100 Nm |
| Conditions of disappearance of the fault | Driving with the engine hot for 5 minutes with several accelerations under full load for 10 seconds With foot off in between |
| Down-grade modes if fault present | Deactivation of the pilot and post-injection injections Deactivation of the request for regeneration of the particle filter from the diagnostic tool Deactivation of the EGR function Cutting of the exhaust heat saver function Prohibition of regenerations of the particle emission filter and stopping of those in progress Deactivation of the kick-down for automatic gearboxes Limitation of performance Request for emergency closing of the turbocharged air cooler by-pass Deactivation of the tight spot for the cruise control |
| Switching on of the warning lamp and/or warning message | Warning lamp MIL |
| Main customer complaints likely | Noise Diesel fuel consumption a bit higher Lack of power Engine hesitating, cutting out Smoke from the exhaust |
| Suspect areas | Manifold air entry pressure sensor Turbo air cooler by-pass unit Electrovalve of the turbo air cooler by-pass unit Position indicator of the turbocharging air cooler bypass unit Turbocharger Turbocharger solenoid valve Position indicator of the turbocharger |
KennyW
- x 165
Marc,
Mileage approx. 151,000miles, top up additive approx. 18 months ago.
So, having PEF deep cleaned or replaced would help ?
This one has me scratching my head.
Kenny
Kenny
- x 6945
Aha! So recommended replacement of the particle filter on this engine is 120k miles Kenny.
So a deep clean (but be wary of the internals as the ceramics can crack if cleaning) may be a solution, then you will have to tell it that it has been replaced and again reset the additive counter after.
KennyW
- x 165
Thanks Marc,
KennyW
- x 165
Well spoke to 3 companies who have the equipment to clean the dpf but they were not willing to just clean dpf without a checking for the faults and sorting the faults first.
2 did not give a price saying it would depend on the faults but on quoted £200 minimum.
So I replaced the cat/dpf which cost £410 and I'm going to reset the counter for fluid.
Where is the replacement exhaust 'button' hidden ?
Kenny
Kenny
- x 6945
Yes, you will need to go into the engine ECU, then repair menu and there should be a section in there for the particle filter - and again somewhere to tell it you have replaced it. Must do that so it can zero out the soot loading back to 0 Gms.
I also note that there was an engine ECU software update Kenny from RPO 13512. Your RPO is 12296. So at some point when the wallet has recovered, it might be worth swinging by the dealer and asking them to update the engine ECU software as you have had the DPF replaced.
You can check your software in the engine ECU - there should be a section giving you the current version - the table below is the updated version:
| Reference | Supplier | System | Application | Version | Edition |
| 96 916 704 80 | 13 | 10 | 1 | 3E | 0061 |
KennyW
- x 165
Thanks Marc, the wallet is slowly coming around.
Citroen price for the part is only £1800. Matches the steering rack nicely!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Kenny
Kenny
