Ds3 apple carplay
This section is for General Enquiries or for Systems not Covered Above
Moderator: GiveMeABreak
Post Reply
johntom
My Cars:
Ds3 apple carplay
Post by johntom »
Hi
I’ve just got a 66 reg DS3 with apple carplay, mirrorlink, is it possible to update the software to make it work, if so is it maindealer only ?
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5742
Re: Ds3 apple carplay
Post by GiveMeABreak »
What is your VIN?
johntom
My Cars:
Post by johntom »
C15 Romahome White
CX 20 Polar White
x 5742
As far as I can tell you need a later unit for this function (SMEG+i V2).
Put up your Firmware and software version info from the unit.
johntom
My Cars:
Post by johntom »
Hi
does the unit need to be removed for the info or can it be accessed from the menu some how ?
johntom
My Cars:
Post by johntom »
Found it !
It’s SMEG6.3.C.R11
Dated 09/05/16
Display software 42.03
Bluetooth software 1.2.0
C15 Romahome White
CX 20 Polar White
x 5742
Ok, so there are a few updates to newer firmware available for your system. But is would suggest you get the dealer to do the updates from their servers for you, as they may also need to enable it using Diagbox. Some of these can only be updated directly from the servers.
If you don’t let the dealer update it, you will likely find certain functions will be missing or not working, because the system needs recalibration and the correct options restored after the latest firmware is applied.
johntom
My Cars:
Post by johntom »
Thanks for taking the time to reply, I will get in touch with a dealer as advised
chris_1969
My Cars: DS7
M Sport BMW
Jag XF R Sport
Post by chris_1969 »
Johntom, how did you get on with the dealer, my wife’s DS3 2015 has the software embedded I think, needs activation by the dealer.
johntom
My Cars:
Post by johntom »
Hi
Yes it went into the dealer and they activated the carplay, unfortunately it cost about £90
DavieS3
My Cars: DS3 DStyle
Post by DavieS3 »
Hi Chris
Did you manage to get your wife’s 2015 DS3 enabled for Apple CarPlay. I have the same on my 2015 DS3 but so far all dealers I have spoken to won’t or don’t know how to do it. Any advice from anyone who know who can activate this for me would be greatly appreciated! Thanks Pete
C15 Romahome White
CX 20 Polar White
x 5742
It will be a software update that the dealer performs - they will download it form their servers and check your configuration parameters afterwards. That's why there is a diagnostic charge of abut £90 which equates to about an hour.
DavieS3
My Cars: DS3 DStyle
Post by DavieS3 »
I would love to pay someone to activat Carplay for me, so far I have been frustrated. I have contacted 5 dealers, and explained to them that I have the SMEGiv2. But none of them will even attempt to try and enable it for me.
I have been given the following reasons:
1. You don’t have the correct hardware.
2. It is not an option on your vehicle (based on VIN)
3. Citroen can’t touch it, it needs to be done by a DS dealer,
4. Your model does not have an Apple Carplay license.
One dealer said his understanding is that although I have the correct hardware.. Apple Carplay can only be activated on certain models as an extra feature. And my Car is not one of these.
Can anyone help or direct me to someone who can?
Many Thanks
Pete
DavieS3
My Cars: DS3 DStyle
Post by DavieS3 »
Hi johntom, can I ask what dealer activated Car Play for you?
My unit is running firmware SMEG6.3.D.R6
Thanks!
Pete
C15 Romahome White
CX 20 Polar White
x 5742
DavieS3 - pop your VIN up so I can see what unit you have. But from the software version I think it is compatible. The only way to get it available on the system is a dealer download as mentioned earlier. PSA dealers initially had a USB they could order whilst they were completing the web links for the electronic download of the required update files.
This is no longer available as they should be able to download and activate the functionality automatically from their servers. I think it is more likely a case of 'reluctance' and lack of knowledge from many dealers as to how and what they have to do to enable it, so many fob people off. There are exceptions of course, where the very early units were not compatible, so this may be true in those cases.
Post Reply
