Wanted
RPWC
x 21
Wanted
Unread post by RPWC »
Has anyone got any brake disc locating screws? I changed the discs and pads on my Dispatch and on one side I dropped one screw and lost it, the other one is a bit dodgy as the torx fitting was slightly stripped.
Cheers Rich :wink:
x 1238
Re: Wanted
Unread post by Peter.N. »
x 1044
Re: Wanted
Unread post by wheeler »
if you need one quickly you can borrow one from one of your door latches till they arrive, they are normally the same screws & the latch should be fine for a few days with only 2 screws in it
RPWC
x 21
Re: Wanted
Thanks for that no hurry aa disc has got one screw in it
Cheers Rich :wink:
van ordinaire
(Donor 2017)
x 402
Re: Wanted
Many vehicles don't use them, si I wouldn't worry too much, after all, once the wheel's on, the disc's not going anywhere :-D
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
