Correct high ind front and back of Citroen C5 1.6 hdi 2006,0
alfehans
New User
Unread post by alfehans »
Any one now that correct higt adjustments off Citroën C5 Serie ll From 2006,
My car is very loss in the front off the, is jumping up and down,
Please the correct higt in cm and not a link to a formula,
x 6945
Re: Correct high ind front and back of Citroen C5 1.6 hdi 2006,0
The height correction is set at the factory (height correctors front and rear) and once this is done, the reference heights are then programmed into the suspension ECU.
There is only limited adjustment that can be made using the suspension ECU and this is done using a formula to arrive at a figure - which is then input into the ECU - this figure is then converted into a value by the suspension ECU that is not the same as a measurement. So we can't just give you a measurement to enter - it does not work like that.
Try and explain what is happening as clearly as possible (use Google translate if English is not your first language).
