peugeot 308
alan308peugeot
peugeot 308
Unread post by alan308peugeot »
Hello,
I have a Peugeot 308 2009 my rear fog light does not come on but showing on dashboard also my passenger window only works from that doors button.
I have tried a BSI reset but still the same.Any advise would be gratful.
x 6954
Re: peugeot 308
Rear fog - have you checked the bulb? I know it's obvious but you didn't say you had.
As for the passenger window, take out the driver's control pad for the windows (the unit can be gently levered out using a trim removal tool or other flat blunt tool. There are a few clips that need to be pressed in and then you should be able to lift it out. Tale the wiring plug off and check the connections / clean them up with some electrical contact cleaner. That'll usually sort it - but if not, also check the wiring loom that will be contained in the rubber / plastic protection tube in the Driver's door by the hinge. This carries the loom from the engine bay to the driver's door and through into the rear doors. The wires can become worn / strained and crack.
alan308peugeot
Re: peugeot 308
Hello Marc,
Thank you for your answer to my question.
Yes first thing checked bulb ok.
I did another BSI reset and that allowed the rear fog light to work.
Will try cleaning swiches for windows tomorrow.
Thank you for you advise sorry it took me a long time to reply.
