307 drivers window does not auto up
wwp_al
Unread post by wwp_al »
Hi everyone,
My 307 had the drivers window panel disconnected when I bought it, so I reconnected it, and all seemed fine, but I have noticed that every window will do auto up and down except the drivers, which will only auto down, and not up.
Is this likely to be the embedded controller in the panel, or may I be able to retrain it?
x 6954
Re: 307 drivers window does not auto up
Are you saying you can hold the switch up and the window will rise and therefore it is just the 'One Touch' operation that is not working?
If that is the case, then reinitialise the Anti-Pinch. Lower the window fully, then manually raise the window with your finger held on the button. If it stops at any point release and keep applying until the window reaches closed position. As soon as it reaches the closed position, keep your finger on the button for a few more seconds - you may here a little click. That is reinitialising the anti pinch. It often need to be done after a battery disconnection.
There is not other procedure to reset this - so if that has not worked then you probably need to check the control module / clean it with some electrical contact cleaner or replace it. I assume it was originally disconnected for some reason?
wwp_al
Yes, it is only the One touch that doesn't work, so a small inconvenience rather than a major issue.
Thanks for that, I did try to reset it, but it is still the same. I will try cleaning things up.
I haven't had any issues since I reconnected it. It may have not been properly connected and just dislodged (he says hopefully.....)
I think the switches are 2 levels, the first being move, the second being one touch full move, so I guess it is just dirt or failure of the second stage. I will check after I have replaced the centre box, so hopefully this weekend....
x 3295
I have had this happen on my C5. When I ran a Lexia diagnostics it pointed towards the switch unit. Upon opening it up I found some of the contacts were dirty. I cleaned them using IPA cleaner and Servisol, and now they are working properly.
wwp_al
It was simply the switch, someone before had taken it apart and not put it back together properly. I thought I had fixed the more important part, windows, and broken the door mirror adjustment, but it seems I too had failed to put the connector in properly, and so the passengers window seemed to stop working. It is all much better now I have the connectors in properly though.
Thanks for all the ideas.
