Citroen DS3 1.6hdi engine fault code P2562
CitroenJohn
Unread post by CitroenJohn »
Hello all, I have a 2013 1.6hdi DS3 which I use every day as a driving instructor. It came up with an engine management fault yesterday and I used one of the cheap generic fault code readers to identify the fault. (I do have the Lexia program installed on my laptop but now it refuses to open due to an "internal fault")
The code reader says P2562 Turbocharger boost / Control position / Sensor A Circuit. When I search this code on youtube, I find results for a Turbo Actuator Position Sensor Solenoid, which shows how to remove a round plastic cover from a plastic unit which has rubber hoses going to it. You then clean a small foam filter inside, which may have become oiled. I can't even find this unit on my engine.
My garage friend pointed me towards a unit just below the turbo intake pipe, which he thought was the faulty part. I have attached two photos (if I can manage it): one shows the end looking towards the middle of the engine (Turbo inlet tube above) with the socket where the wires connects and the other shows the other side showing the control rod coming out of the unit, which presumably controls the turbo. I'm not sure what part I am looking at here and if it it is the one responsible for the fault. Can anyone shed light on this for me please, and hopefully an appropriate remedy?
Thanks in anticipation.
Hamza_112
Re: Citroen DS3 1.6hdi engine fault code P2562
Unread post by Hamza_112 »
Were you able to resolve the issue? as my car also has come up with this fault code!
x 6957
I'll need your VIN for the correct code details as per your engine as there are 4 or 5 versions of this engine fitted to the DS3
Hamza_112
GiveMeABreak wrote: 08 Jul 2019, 14:58 I'll need your VIN for the correct code details as per your engine as there are 4 or 5 versions of this engine fitted to the DS3
The engine that's fitted on my ds3 is a EP3/C
x 6957
I need the VIN, that’s no good to me., there are 8 EPC6 engine variants, no EP3/C
Hamza_112
GiveMeABreak wrote: 08 Jul 2019, 21:51 I need the VIN, that’s no good to me., there are 8 EPC6 engine variants, no EP3/C
Sorry about the that, where do i find the engine VIN?
x 3306
The VIN is normally visible through a small window in the black surround of the windscreen (normally bottom left), and it is also on the V5 logbook.
The VIN is, effectively, the serial number of the car. People with the right access can then look up exactly what the vehicle had when she rolled out of the factory. For security reasons the VIN will be obscured so that only Forum Moderators can read it.
Hamza_112
Hell Razor5543 wrote: 09 Jul 2019, 18:35 The VIN is normally visible through a small window in the black surround of the windscreen (normally bottom left), and it is also on the V5 logbook.
I will Private message you the VIN
x 3306
You can post the VIN on the forum. It will be obscured so only Moderators can read it. I am NOT a Moderator. I believe that, if you PM it, the VIN will be obscured in the PM so NOBODY can read it.
x 6957
Hamza_112 wrote: 09 Jul 2019, 19:33
If you want to send it via a PM, then send it to me - I can read it in a PM.
Hamza_112
GiveMeABreak wrote: 09 Jul 2019, 19:42
DONE
Hamza_112
The VIN is: VF7**************[VIN obfuscated, can be read by forum staff]
x 6957
Right, as I suspected, you had neither of those, you actually have a DV6DTED engine.
So here is the description of the fault for this code as it relates to your engine ECU:
So you'll need a Lexia with Diagbox in order to get some live data to see what's happening, but this should give you some pointers.
Fault codeP2562
After sales description of the fault codeTurbocharger: Position incorrect relative to requirement, not enough turbo
Description of the diagnosticsThe position measured is greater than the reference by more than 20% for 4 seconds
Conditions of activation of the diagnosticsThe following conditions have to be met
- engine running
- Engine speed between 1500 and 4000 rpm
Conditions of disappearance of the faultDriving for 5 minutes
Down-grade modes if fault present-
Switching on of the warning lamp and/or warning messageWarning lamp MIL
Main customer complaints likelyNoise
Smoke from the exhaust
Lack of power
Loss of braking
Suspect areasTurbocharger
Turbocharger fixed geometry control electrovalve
Turbocharger fixed geometry position repeat sensor
EGR exchanger with bypass
EGR exchanger bypass control solenoid valve vacuum pump
Electrical harnesses
Jack53
New User
Unread post by Jack53 »
Hi there. Any luck resolving. My same engine reports this code once every two months and then clears itself. Any help would be appreciated. Jack
pkuc003
New User
Unread post by pkuc003 »
Hi. I have same code. Can you tell me how you fixed it?
