On a recent holiday in France all the diesel pumps are marked B7, 7% bio added.
Just recently my local Esso garage is now displaying B7
Is this likely to give problems with filters.
I have read many differing reports on Bio and clogged filters.
Does anyone have any practical experience with Bio diesel?
Your comments would be appreciated.
Benita
Bio diesel
- x 5671
Re: Bio diesel
I ran my C5 (2.0HDi) on bio for six months - it was made on the estate where I worked for the fleet of the company that made it and had the advantage of being very cheap (78p/L).
It was fine, no problems whatsoever and the advantage that the exhaust smelled positively nice, not like a chip shop but a bit like Isopropanol.
I did change the fuel filter more frequently just in case but it wasn't necessary
Unfortunately they stopped selling it, just kept it for their fleet.
- x 6956
Re: Bio diesel
All Citroen and Peugeot models introduced after 1 January 2000 are already compatible with B7 Diesel, as are all DS models. Any models released prior to this date are not compatible with B7.
- x 1751
Re: Bio diesel
All diesel here is now B7; think it has been for some time.
No running issues at all, and good performance if you use leading brands.
Even better with a dash of Millers/Wynns/3CV
Benita
- x 4
Re: Bio diesel
Thank you all for your replies.
I feel more re-assured now.
Thank you, Benita
Thank you, Benita
- x 1938
Re: Bio diesel
For a few months about 3 - 4 years ago I ran both the Mk1 C5 and the Xsara on full bio without any noticeable ill effects.
- x 6956
Re: Bio diesel
- That's from PSA direct. Of curse highly unlikely you are going to damage your vehicle with a few tankfuls if you do use it on an older car - as the results are likely to be cumulative over a period of time. At least you have the official position.GiveMeABreak wrote: 08 Jul 2019, 19:29 All Citroen and Peugeot models introduced after 1 January 2000 are already compatible with B7 Diesel, as are all DS models. Any models released prior to this date are not compatible with B7.
kenbw2
- (Donor 2017)
- x 24
Re: Bio diesel
Good thing I'm using veg oil then, no B7 for me
van ordinaire
- (Donor 2017)
- x 402
Re: Bio diesel
As I recall, bio-diesel starts off as veggie.
Citroens:-
'81 2CV Club
'05 C15
'97 Xantia Exclusive estate
others:-
Jeep XJ Cherokees x 3
'96 Cadillac Eldorado
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
- x 5671
Re: Bio diesel
The stuff I used was made from used veg oil from local chipshops and pizza places.
Eventually there were too many collecting it and the chipshops started charging for it so it became hard to get and uneconomical, so the biomaker started using virgin rapeseed oil. Slightly more expensive but a cleaner easier material to work with so it just about broke even.
- x 1938
Re: Bio diesel
Biodiesel is a con if the fertilisers used are made from petrochemical stock.
- x 5671
Re: Bio diesel
It's all a con.
