C5 II runnig hot (overheating) when towing
- x 1746
EDC5
- x 130
Re: C5 II runnig hot (overheating) when towing
Very interesting! maybe the ECU can choose to increase the engine operating temp to increase efficiency at low engine loads but allow proper cooling when required.
I've always thought PSA vehicles ran too cold, around 80 or so rather than the 90 or so for virtually every other make I've experienced, so this system would appeal to me, if it does indeed work on that principle.
Romzi
- x 7
The "new" system is very much simplified, and exacly the same unit is used on Peugeot, Ford and Volvo (in fact the "same" engine), some Fiat and Lancia engines, so I assume It's good enough for Citroen too.
osx
- x 15
Had the alternator belt snap while i was on the motorway. First i got a battery warning, next faulty handbrake warning and finally power steering warning and service lamp.
C5 X7 Exclusive 2.0 HDi Auto
Romzi
- x 7
Some news about my "frog".
It still doesn't run cool enough when in hot weather and towing.
I discovered that only this type of C5 (2.0 HDI 2004-2007) and some P407's have the same cooling fan arrangement.
Stock fan is only 150W rated power, but allmost any other 2.0 HDI on the planet has at least 350W cooling fan, or even two of them. For examle C5 MK1 2.0 HDI ( only 83kw) has 3-speed 500W stock cooling fan for vecihles with AC and about 350W cooling fan if the has no aircon. Xsara 2.0 HDI has 350W cooling fan.
I just think it's bad design!
Newer and stronger cars also have quite higher power rating of cooling fans.
Some aftermarket cooling fans for may car are also much higher power rated, for examle: https://www.autodoc.co.uk/tyc/10280307
In the other hand, there are cooling fans for MK1, which are much cheaper (without fan control module): https://www.autodoc.co.uk/van-wezel/1279864
The question is, can I somehow fool my car too use the older and simpler design (with use of power resistors) without warning light come on? Is engine ECU aware of the speed of cooling fan or it's just giving commands for speed without feedback about waht is really happening to the fan itself?
Does anybody have and is willling to share cooling fan wiring and logic for may car? It's C5 break 2.0 HDI, year 10/2004.
- x 6945
Not recommended, because the engine ECU and the cooling system is designed to operate specifically in a certain way with the air conditioning ECU and the sensors to obtain optimum cooling - according to the situation. If you start changing the system you will probably end up affecting other parts of the system which can have undesired consequences.
Back in the MK I days some of the petrol fans were 500 and 450 W fans and the 2.2 had 2 x 150W fans - but as time has moved on with Euro standards getting stricter, they needed to reduce electrical power consumed and consequently fuel consumption / emissions - so they redesigned the cooling systems to work in a different way so that they consume less power. Even the later petrol engines had reduced capacity fans - the petrol versions I mentioned earlier were reduced to 160 watt.
In your case (DW10BTED4 138Bhp, build date 2 October 2004) , the fan is 150 Watt, but from build number 11055 (14 February 2007) they did increase it to 160 Watt.
Romzi
- x 7
I know that, but newer models are again using more power consuming fans.In your case (DW10BTED4 138Bhp, build date 2 October 2004) , the fan is 150 Watt, but from build number 11055 (14 February 2007) they did increase it to 160 Watt.
Also, C8 with the "same" engine and aprox. same age is also using much more powerful fans.
Isn't that strange?
- x 6945
No, that's strictly not true. It all depends on year, engine type and size and what options they have, FAP for example.
I have the same engine (albeit a bit later ) and that too has the 160W fan.
Only the bigger engines now have the twin fans like the 2.2, 2.7 and 3.0 diesels using the X7 as an example. Even the 3.0 V6 petrol X7 has a 160 watt single fan.
But the C8 production ended 2010 used a lot of the same engines as the older C5, but because it is a people carrier and likely to have additional rear air conditioning and more equipment and be heavier, it has the additional cooling. Look at the new C4 Picassos - these are the latest engines and they only have 140W single fans, with one having a 200W.
- x 1746
It could be that some attention has been paid to fan motor design, to enable great air flows at reduced current demand: 500W (or even 300W, and certainly 300W × 2) is no joke at 12-14v !
That still leaves Romzi's C5 II seemingly under-cooled for towing, assuming everything else (like thermostat and water pump) is working well. 1 × 150W does seem a bit marginal; cabin heater fan could be more 'powerful'!
Marc, could you post a circuit diagram for the car's cooling arrangement, just out of interest?
- x 6945
Sure, give me a minute... Also consider the max. towing weights too - we have another member querying the towing weight - who thought is was a bit low - that can cause overheating of course if exceeding limits.
- x 6945
Here you are, (no Particulate Filter on this model either). Note: For the C5 II with DW10BTED4 with no FAP.
Equipment
1513: Cooling Fan Electronic Mixer Unit
Wires
1590: Fan unit relay power supply
1599B: Fan unit diagnostic info
1540B: fan control 1 (-)
B160: To Maxi Fuse
M153: Earth
Equipment
Wires
B160: To Maxi Fuse
M153: Earth
- x 5672
I wonder if it would be feasible to fit an uprated fan?
Bodgery may be called for.
OnlinePaul-R
- x 1939
Feed a heavier duty fan through a fused relay direct to the battery. This will only work if it's single speed though. And there's always the complication that whatever ECU is looking after cooling might measure current pull and a relay coil would be significantly less than a fan motor.myglaren wrote: 05 Jul 2019, 19:01I wonder if it would be feasible to fit an uprated fan?
Is there scope for a second fan on the radiator?
- x 6945
To answer your questions:Romzi wrote: 05 Jul 2019, 13:25 Is engine ECU aware of the speed of cooling fan or it's just giving commands for speed without feedback about waht is really happening to the fan itself?
Wiring Diagram is now up.
As for what is happening:
You have a 2 speed fan on your vehicle (the 3 speed version was fitted to some ES and EW petrol engines).
The engine ECU determines the fan speed based on information from
- The Engine Coolant Temperature Sensor (1220 on the diagram)
- The Air Conditioning Circuit pressure measured by sensor
- The temperature of the Auto Gearbox (where fitted)
Between 97°C and 105°C, the engine ECU commands the chopper control on a staged basis
If the temperature reaches 105°C, the engine ECU commands the cooling fan to operate at fast speed
As far as the Air conditioning goes a sensor (Aircon Fluid Pressure Sensor 8009). The linear pressure sensor allows the pressure of the cooling circuit to be measured, which enables the engine ECU to control the slow or fast speed of the fan unit.
- x 6945
Single fan only and no room for another fan in the housing, plus this is a twin speed system.Paul-R wrote: 05 Jul 2019, 19:26Feed a heavier duty fan through a fused relay direct to the battery. This will only work if it's single speed though. And there's always the complication that whatever ECU is looking after cooling might measure current pull and a relay coil would be significantly less than a fan motor.myglaren wrote: 05 Jul 2019, 19:01I wonder if it would be feasible to fit an uprated fan?
