Why no wire for the brake on the other side ? Brakes are not split side to side so no separate circuit
Do I need to take a wire over for the fog light also ? No, same as the brakes
Last thing now, when I connect to the battery with cable and 15amp fuse, do I need to take off the negative wire, in order to connect the cable to the positive wire, ? Don't want a shock or spark wondering.. Yes, it avoids any potential issues. Note you need to take account of the battery disconnect / reconnect procedure for multiplexed cars:
BSI Rest / Battery Disconnect / Reconnect Procedure
Which in the case of a Xsara Picasso involves sitting in it while it goes to sleep, and then afterwards whilst it wakes up again - hopefully it won't be -10°C like it was when I had to do it....!
xsara picasso 05 multiplex, towbar electrics Help.
- x 1486
