Gearbox Whine advice please
x 1938
Re: Gearbox Whine advice please
Yes, there were few 90bhp models so it was unlikely that fastjet would be lucky.
x 6956
A bit late to the party, but if it helps....
As per VIN, Fastjet has a DW10ATED 110 with the BVM5, ML5C gearbox. The ML5C compact version is an evolution of the ML5T Gearbox:
  • Reduction in length: 14 mm
  • Improvements in the gear change forces and travels
  • New "chandelier" type gearbox control grille with specific gear lever gaiter
  • Reverse gear unlocking device
  • New flexible support for the transmitter on the hydraulic clutch control
  • New reverse gear switch
  • Increase in oil quantity due to the engine tilting
Gearbox RatiosSerial Number: 20 LM 23
1st12 x 41
2 nd23 x 41
3 nd33 x 37
4 nd44 x 35
5 nd51 x 31
Reverse Gear12 x 23
Crown Wheel and Pinion16 x 65
Speedometer Drive GearWithout
Key
ReferenceDesignation
15th gear synchronizer
25th gear
3Reverse gear intermediate pinion
4Reverse gear sliding pinion
5gearbox casing
6clutch housing
7Reverse gear sliding pinion
8Reverse gear shaft
9Reverse gear needle thrust bearing
10input shaft
11output shaft
12Differential crown wheel
13planet wheels
14differential box
15sun wheels
16differential bearing retaining plate
17Reverse gear driven pinion
181st gear driven pinion
191st/2nd gear synchronizer
202nd gear driven pinion
213rd gear driven pinion
223rd/4th synchronizer
234th gear driven pinion
245th speed driven gear
25Steel casing
x 1938
GiveMeABreak wrote: 23 Jun 2019, 20:23A bit late to the party, but if it helps....
It all helps. I was always getting the ML5C and ML5T mixed up and hopefully I'll now remember which way round they go and what the difference is.
x 6956
I removed the gearbox ratios for the other boxes because I didn't want to cloud the issue, just leaving the 20 LM 23 one there (serial number for this Box).
fastjet
x 8
Unread post by fastjet »
Hi, thank you for the diagram.
Looking at the diagram there would appear to be two bearing in the end of the gearbox, one behind the 5th gear and the other directly underneath. If I take the steel plate of, will I be able to replace the bearings?
