Taking an old friend to get her pension yesterday had to brake quite hard to avoid a young pheasant/partridge (Must look that up) waddling into my path.
Pulling away again the car bounced along like the suspension was completely absent, by now at a busy crossroad had to continue a bit further before stopping.
Had a think then asked the old girl "Did you put your hand on there?" pointing to the high-low button, "I might have." she replied.
Sat for a while doing Citrobics then set off again, all back to normal.
Not nice!
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4888
Re: Not nice!
Doesn't yours flag up a warning when it is in low, and return to normal when you start to move?
- My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE - x 2500
Re: Not nice!
I don't know about that Steve but it was in high and solid.
Man is, by nature, a lazy beast, he does not need twice encouraging to do nothing.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5644
Re: Not nice!
Yes, it will do - but if in high (max. speed 6 MPH), probably took a while to get to the speed limit and a little longer to lower again, - but if it was accidentally only in intermediate height (max speed 25 MPH) it would of been enough to give a bumpy ride until it lowered again back to normal.
Re: Not nice!
I think that hard braking must have done some mischief to my suspension, went out in the car this morning and it's gone hard again, the front won't come down unless it's dropped right to the bottom setting, set it back to ok and the front is again too high.
And it's peeing down with rain out there.
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1280
- Contact:
Re: Not nice!
Sticking dog bones/height correctors.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
Re: Not nice!
My thoughts too, I wonder if the dog bone has popped off or broken but it's too wet to get under and look at the moment.
Re: Not nice!
Finally got to have a look at this, nothing broken and it seems to have settled back to normal without any intervention, I've driven it sixty miles or so.
Whilst out there I decided to run a diagnosis with the WoW Snooper, all ok except for two codes P1351 Pre-post heating relay control circuit fault/not connected, which I'm told is usually best ignored and P2408 Diesel additive system defect filler cap sensor or additive level error.
