Forum maintenance and reconfiguration
Forum News, Announcements and any issues you're having with the forum
x 1452
Unread post by xantia_v6 »
Over the next week or so I will be making some adjustments to the configuration of this server, and installing some application software updates.
There will be some brief disruptions to normal operation, but these should only last a few minutes. I will be carrying out this work between 7am and 4pm UK time.
As there are several different tasks and software packages involved, I can't give a specific timetable.
Mike
x 1452
Re: Forum maintenance and reconfiguration
I am currently testing a change to the server configuration for this site, which should not have made any noticeable difference for normal users.
Please tell me if you see anything strange in the forum operation for the rest of today.
x 1938
How abnormal does a user have to be to notice a difference? :rofl2:
x 1452
Mere eccentricity is insufficient.
x 1751
I think we should all form an orderly queue . . . :spineyes: :spineyes: :spineyes:
x 3306
white exec wrote: 09 May 2019, 13:52 I think we should all form an orderly queue . . . :spineyes: :spineyes: :spineyes:
An orderly queue from this disorderly rabble? You are asking a bit much, aren't you! :D
x 1452
Back to topic :shock:
I will need to take the forum off-line for an hour or so tomorrow morning to test a new server configuration. I will probably start around 8:30 am.
x 1452
I have made the main reconfiguration, which seems to have been successful, but I need to make some further tests and adjustments over the next few days. This may result in a occasional dropped connections and error messages.
I am aware that wiki images are not currently displaying correctly, I will fix that later today. Let me know if anything else seems significantly broken.
x 7164
Something new. Had to do a capture (capcha? something like that-you know what I mean) question to login for the first ever time. Unaware as the message indicated that I had made too many attempts to login...
Yes went in and out and it required another captcha
x 5671
NewcastleFalcon wrote: 10 May 2019, 23:19 Something new. Had to do a capture (capcha? something like that-you know what I mean) question to login for the first ever time. Unaware as the message indicated that I had made too many attempts to login...
Same here just now.
x 1452
Sorry about the login issues. I don't know what has caused them (something to do with cookies I imagine). I am hoping that it only affects each user once.
x 6956
Ditto again this morning
x 1751
Same yet again here.
moizeau
x 429
Unread post by moizeau »
Fine here, straight in as normal, yesterday evening was down, but you knew that....I hope
Pete
x 1452
I have changed a cookie parameter which may fix this issue. If it is still happening, I will reset all of the cookies on the server (which will log everyone out).
