FLAT BATTERY C2
markh
Re: FLAT BATTERY C2
Unread post by markh »
Well found 2 glow plugs as soon as i disconnect the lead on number 2 the draw went
thanks to ever one for you input :clap: :clap: :spit: ](*,)
markh
Re: FLAT BATTERY C2
Hi all found it number 2 glow plug thanks for ever ones help
x 6955
Re: FLAT BATTERY C2
Excellent - well done - so are you after a new relay? If you need the part number pop your VIN up here.
markh
Re: FLAT BATTERY C2
GiveMeABreak wrote: 09 May 2019, 14:39 Excellent - well done - so are you after a new relay? If you need the part number pop your VIN up here.
Hi all sorted new plugs and new battery be here in the morning thanks for your help =D> =D> =D>
cheers Mark
x 1056
Re: FLAT BATTERY C2
Unread post by wheeler »
Surley its the Relay (or something that's controlling the relay) that's the fault here? Cant see how the glowplug itself can be the problem??
