Can anyone tell me if the self adjuster kits from GSF for the ZX are to do both sides or do I have to buy 2 kits? (self adjusters are missing entirely from a mates car!) Cheers in advance
ZX Rear Brake Self Adjusters
tonespeed1999
when you say the self adjuster is missing!. i presume you mean the tiny metal flap that sits under the adjusting nut?
if so this is quite common,alot of garages tend to "bin" them during routine maintanance,too fiddley to refit if knocked off.
only problem is they wont adjust the shoes as they are designed to do.
the adjusters are available as a kit for each side,depending on the make and how the supplier sells them.
wilkobob
sooty
- x 1431
wilkobob
wilkobob
citroenzx
tudor
wilkobob
