Xantia activa 2.0 TCT front brakes on 1.6i
tioklou
Unread post by tioklou »
Hello,
I have a set of xantia 2.0 turbo front brake calipers a new set of 283x26 disks and a new set of pads. I tried to install them on my 1.6 xantia x1 but there is a problem. Calipers could be installed on the knuckle hub but the disks could not sit on the center of the caliper! Is there a solution to the problem or only to change the knuckle hubs?
Thank you very much
Best regards
Panos
x 1450
Re: Xantia activa 2.0 TCT front brakes on 1.6i
Unread post by xantia_v6 »
I am not sure of the exact compatibility of brake parts, but Xantias fitted with engines that use the ML5 transmission (TCT, V6 and HDI 110) have a wider front track and use different hubs and carriers.
tioklou
Thank you very much for your quick answer. The use of hubs and carriers of a Tct Is it possible to be installed on my car? With stock 1.6 axles etc. or is it possible to use 283x22 discs with tct calipers because in this way the problem will be solved
Thank you very much
x 1450
tioklou wrote: 01 May 2019, 09:37 Thank you very much for your quick answer. The use of hubs and carriers of a Tct Is it possible to be installed on my car? With stock 1.6 axles etc.
Thank you very much
I am not sure about that. I think that you may need longer driveshafts, but the ML5 driveshafts would not fit your BE3 transmission.
tioklou
Yes i understand! I think that a solution would be to use the 283x22 disks with the stock tct calipers but could this be done? In order to be safe of course.
Thank you
