The round one that lives within the housing for the O/S driveshaft.
Has anyone ever changed one? Mine is as soft as cheese. I thought when I had the engine out next week, and the shaft out the way, I would have a go. The replacement is a metal disc with the rubber bit inside. Is it an inferance fit..does it need heat? I've only ever done one and then I replaced the entire mounting, not just the disc.
XUD lower Engine Mount
mrbump
Hi jon,
Yes it is a very interfering fit!
You will be hard pushed to drift it out, and heat will set fire to the rubber. What i did was to remove the mount from the engine, put in a vice, take a hacksaw blade, thread it through the mount (with as much rubber cut out as possible) and then connect it to the hacksaw. Cut about a mm or two nice and perpendicular into the metal disc , and you will then have that space to compress the metal disc part of the old mount and drift it out. Dont get too handy though or else you will cut into the alu.
As haynes says "installation is a reversal of removal"!!! Reckon you might need a press to get it in straight, or a good vice with wide flat jaws. Keep tapping all the way round as you compress it.
Jon
vanny
if your gonna stick it in the oven then cut the rubber out first! Having looked at these they dont seem very clever, i dont think you CAN press them out as the rubber will tear out before hand, and you cant just press the metal ring out as there is a lip on the mount bracket!
There is always the method of cut the rubber out (very easy to do, even if your not trying) then as suggested cut the ring. Other option is to weld a couple rings in with a mig welder and try to cool the thing and hope it will pop out. Dependant on corrosion you might find it simply goes pop and falls out, but my experience with the BX is that salt corrodes everything and very little wants to give up its hold!
Other option is a new mount!
And you'll need a press to get it back in (my local garage usually obliges!)
jeremy
Jon
I did mine on my TD without removing anything except the yoke. I sawed through the outer ring with a hacksaw (full size one - the blade threads through the slot in the mount) and then drove it out.
I froze the new one to give a little more clearance, put a dab of grease on it and was able to tap it into place without much trouble.
Seemed easier than removing the mount, driveshaft, driveshaft bearing etc. In reality it wasn't very difficult and if I'd known that the method worked when I started I would have probably been much quicker.
Jeremy
Jeremy
- x 1431
ActivaV6uk
oilyspanner
I clamp the ally bracket holding it all in a strong vice, remove the rubber bit (normally rotted with oil) and using my no1 hammer and a small chisel peel the outer steel ring inwards, once the circle is deformed enough the bush drops out, i then grease the new one and press it into place using the same vice, easy!
Stewart
Stewart
vanny
jeremy
vanny
mrbump
vanny
IF i'm thinking about what your thinging about then yeah there not too bad (electric Jigsaw) and better as i have one of my own with metal blades in, and i can be quite accurate with them, problem is getting them near anything while its on the car is pretty much impossible!
(ps i finally made it to 500 posts!)
jeremy
