Citroen c5 1.6 hdi 2007 vtr
Hi I have had a depollution system fault for a few weeks it has go off a few times and came back on.
It all started with a particulate fault that the garage said was due to low fluid and topped it up to be replaced with the depollution fault, when that was put on the fault reader it came back with mass air flow sensor fault so I have fitted a new sensor but it has not cleared. Does it have to be cleared by a computer or should it have cleared on its own? I also have a oil leak on the turbo and the seal from the turbo to the maf is split ( sorry about all this). Is there anything I can do about the oil leak without having to replace the turbo? I will replace the seal tomorrow. Apart from that the car drives well lol
That old depollution system fault
- x 2000
Re: That old depollution system fault
Is the garage using a suitable code reader ?
Without a Lexia I do not think you can reset the Eolys level.
Splits in the induction pipe work can throw off the MAF...give false fault readings.
I would worry about a turbo oil leak, from where is the leak ?
dodger010
Yes the codes for the Eolys was cleared the warning for the depollution has gone now but as it has been intermittent we will see, but it is now sounding rough in low gear but better from third up. I will clean the turbo and try and locate the leak.
