Many problems & don't know where to start
- x 1463
Re: Many problems & don't know where to start
You might want to try turning it over manually to check that the engine is not hydraulic locked by a cylinder full of fuel.
doctle
- x 223
Changing the oil won't really solve any problems except the high oil level. You need to find out whats causing the problems so the car needs to be scanned. There are usually back street mechanics that will scan your car for cheap if you can't afford the dealer diagnostics. There are people on this site that have the dealer level diagnostic tool that would be happy to scan the car. They won't rob you maybe just a few beer tokens or tea and biscuits (chocolate digestives at a minimum)
Oh buggle
- x 1055
doctle wrote: 13 Mar 2019, 22:42 Changing the oil won't really solve any problems except the high oil level.
Of course not but we want to be able to at least start the engine for further fault finding, as it stands at the moment I wouldn't even dream of attempting to try to start it.
- x 1939
We still don't know for sure if a DPF is fitted as the VIN hasn't yet been given. If @Namele55 could post that up we could move on properly.
doctle
- x 223
The faults are stored in the cars ECU starting it isn't necessary
Oh buggle
Namele55
I'll pm the vin number after work this evening
- x 3296
You can safely post the VIN into the Forum. The software will automatically obscure it (although Moderators will still be able to read it).
- x 1994
Keep the oil, let it settle and see if it is ultra thin or water contaminated....also if you can change the filter before refilling.
- x 1939
In fact definitely DON'T PM the VIN as the forum software masks the number and staff can't read it there.
Namele55
Ok so I changed the temp sensor which sorted out the fluctuating gauge, mechanic coming out at lunch time to replace the copper injector seals which he said was what the problem was. Will see what happens when he's done & let you know
Namele55
Ok so the mechanic came out & replaced all the copper injector seals, the ones that came off were absolutely shot!
I took the car out for a small run after he'd done & it seems much more responsive, less smokey & generally much smoother.
So the temp sensor & injector seals seem to have been the problem. Must say I'm glad I didn't have to splash out for new injectors. I'll keep an eye on things & let you all know how it runs over the next few weeks, thank you all for the responses
- x 1746
Good news on getting those two things identified and fixed!
