X7 1.6HDI Service recommendations
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 231
I'm about ready to get my newly acquired X7 serviced including cambelt.
As often advised, it's prudent to replace water pump at the same time when doing the timing belt but can anyone suggest other items worth doing as well that shouldn't add too much to the overal cost but will save having to remove the same protection/access items all over again at a later time?
On my service list are;
Oil, oil filter, fuel filter (I believe air filter was recently replaced), cambelt tensioner & idler pulley, water pump, coolant, serpentine belt.
(I had already pre-purchased a FAI timing belt kit w/water pump (TBK190-6318) for my estate but as I'm planning to sell that car on, believe it will also fit the X7 as the part numbers are identical?)
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
Re: X7 1.6HDI Service recommendations
Mike, the timing kit that includes the OEM Belt, Pulleys, Water Pump & Gasket from Citroen is below - and yes the main kit is the same part number for your C5 II. But on the parts list for the C5 II, they offer a cheaper version for cars older than 3 years, which I have also listed. BUT, they do not list this cheaper kit as an option against the X7 - make of that what you will.....
X7
1609525680 priced at £173.56 inc.VAT
C II
1609121080 Full Kit with water pump - cheaper non OEM parts £128.28 inc. VAT
X7
C II
Yes I saw those two options when researching OEM part numbers to check the FIA kit I have in stock will fit the X7. I think I paid half what Citroen are asking (which boasts as good as or better than OEM).
I also have the Total INEO oil and oil filter, plus coolant - again originally bought for the MKII. Just can't think what other jobs will be worth exploring while accessing the timing kit. Injectors don't appear to need resealing...
Found a few more jobs that need doing, mostly missing or loose fasteners, new air pipe, maybe new PCV as well.
Booked a mobile mechanic to do the cambelt so it should (fingers crossed) be back on the road next month.
- moizeau
- My Cars: 91 BX TZD Estate. Dead but loved
407 HDI 136 auto
C4 2l petrol coupé
2010 Dispatch III HDI 90
AND a 1980 Z1000ST
AND a 1983 GPz1100 inj
AND a 1995 Zephyr 1100
AND a 1980 Z650 (my moped) - x 315
A bought cam and cranks seals and an aux belt kit at the same time as the cam belt kit, though mines done 170000m and showing signs of weeping.
Pete
Good point. I'll ask the mech to notify me if he spots any seal leakage.
If the aux belt I have in stock for the facelift fits this X7, he can throw that on too.
Finally, the X7 is back on the road following a day of "assisting" a mobile mechanic in giving it a damn good servicing.
New cambelt, tensioner + idler, aux belt, water pump + coolant, oil + filter, fuel filter, air breather pipe and new undertray fasteners plus a couple of other minor niggles sorted.
A few issues were encountered along the way.
The only locking wheelnut socket I got has a missing pin but he carefully managed to make it work. (Think I'll replace them with standard bolts)
The Citroen Service procedure gives the torque setting for the cambelt tensioner as 2,5 daNM and idler as 3,7daNm but his bible (Autodata) states the tensioner should be 37Nm and omits the idler torque value. I was left to make the call and requested he use the Citroen specs though it's given me cause for concern to be honest.
The supplied aux belt was shorter but fitted all the same. I'll replace that tomorrow.
A couple of fault codes were inadvertantly triggered but the mech cleared them using his Solus, thankfully... because my diagbox refused to work, asking "Please connect VCI" and failing to read VIN. Previously it would jump straight to diagbox so no idea what's happend to it.
- Donor 2023
- Lexia Available: Yes
- My Cars: C5 X7 2009 2.0 HDI VF7**************[VIN obfuscated, can be read by forum staff]
C4 2010 2.0 HDi Exclusive VF7**************[VIN obfuscated, can be read by forum staff] - x 378
Well all i can say is
And i hope you enjoy it, hope it lives up to expectations now it has had the TLC it was lacking in previous hands
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Check your system has not been deactivated Mike - it can happen on selecting some options. Copy your licence file back over. Or secondly, it should be using Diagbox for the X7, so what version are you on?
Thanks Colin, still hoping you'll come and drive it again and let me know if you notice any differences as it's all still new to me.
I've suffered de-activation before and got a different message so don't think it's that but have a license copy if needed. I want to see if it still works on the estate before making any changes.GiveMeABreak wrote: ↑01 Apr 2019, 18:43 Check your system has not been deactivated Mike - it can happen on selecting some options. Copy your licence file back over. Or secondly, it should be using Diagbox for the X7, so what version are you on?
Yes previously it would find the VIN and jump straight into diagbox but now it first asks to connect VCI (USB driver is present and green light is solid on VCI) then if I progress, asks for the VIN.
If I try auto detection it fails at finding the VIN again. V7.65
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I would drop down a few versions TBH - I wouldn't go above 7.62 - things start dropping out on later versions. This is what I use on my X7 and it still retains perfect compatibility with the 2007 C3 under Lexia.
It's been solid for years Marc, I don't like to mess unless I'm certain it's not something silly I'm missing first in case I just make matter worse... and on that note, while testing a few ideas indoors (off the car) the large round connector (connecting VCI and OBD plug) seperated. Hopefully that was the fault!GiveMeABreak wrote: ↑01 Apr 2019, 19:20 I would drop down a few versions TBH - I wouldn't go above 7.62 - things start dropping out on later versions. This is what I use on my X7 and it still retains perfect compatibility with the 2007 C3 under Lexia.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Oh well - at least you got to the bottom of it!
- Donor 2023
Mike just enjoy it, if you have the "Devil Car " running right you will know, no need for me to tell you what you will find out in a few days of it being your daily driver.
Yes i still miss it, but you had the time and cash to get it sorted, i ran out of time but between the both of us and this great forum you have a cracking car that you need to just enjoy
It's working again with the facelift, so I'm assuming it'll work again with the X7 as the mech's Solus was communicating with it just fine. Thanks Marc.
admiral51 wrote: ↑01 Apr 2019, 21:01 Mike just enjoy it, if you have the "Devil Car " running right you will know, no need for me to tell you what you will find out in a few days of it being your daily driver.
Still a few issues I'm not sure about but feeling happier now the crucial work's been sorted. It is a solid reliable car, that's for sure and I look forward to using it more. I reckon mum will be pleased as she struggles getting in and out of the low-slung estate, bless
