citroen doc backup error code
Bandit12
x 12
Unread post by Bandit12 »
Morning peeps
Just tried to access Citroen doc backup and encountered this error (see attached screenshot) seems to be some kind of javascrpt thing but I'm not pc savvy, any ideas? Scratch that as cant attach screenshot! like I said not pc savvy
It reads "Error initializationbackup Systray:class javanet.Socket extension.
Any ideas?
Bandit
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone) :(
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade) 8-)
Bandit12
x 12
Re: citroen doc backup error code
Quick update, I noticed that my javascipt was an older version so i updated it but it made no difference :-(
harryp
(Donor 2022)
x 73
Unread post by harryp »
No response? I too have a problem. :(
I have loaded Doc Backup and Sedre 3 times over a period of about a year and it appears to install correctly.
However, when I try to run either, I get the same error message;
""Fatal Error
the application is out of date, please update it.""
Date and time are correct, Java is up to date, so what is out of date, or what does it mean?
One thing I did notice is that last night the install code was different to the first two. initially codes were OBE4GAAA, the last was P72NPAAA with different activation codes. Why the differences on the same machine?
Anyone have any ideas please?
Rapidly losing my hair 8-[
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
x 6955
It’s deactivated Harry, the licence is out of date - most likely expired.
harryp
(Donor 2022)
x 73
Hi Marc,
Thanks for response.
Have to say what/which is deactivated and expired? Is this PSA blocking its use? If so will turn off internet when I try again.
I installed from your .iso disks. System was "cleaned" using regedit etc before install so I really don't' understand what is going on :roll: .
Is it the install codes? Can I try using the old ones?
Utterly flummuxed. :?...... again
Regards, Harry
Regards, Harry
x 6955
I will PM you Harry.
Sloppysod
x 365
Unread post by Sloppysod »
Hi Harry,
This may be of help, had similar problems with my copy of Sedre/Doc Back up purchased online a while ago.
It worked for me except it now does not recognise my VIN number, but that may be a fault else where in the system/program.
http://itsupport.me/computer-tips/vmwar ... 4-message/
Good Luck.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
