Transponder codeing
Fra21r+
Re: Transponder codeing
Thanks for the reply Marc
Vin VF7**************[VIN obfuscated, can be read by forum staff]
Citroën relay 2.2 hdi lwb 2002
- x 6948
Ok, so now I have your VIN, I can see that you don't have a BSI on this model. I should of asked for this earlier as a lot of what has been posted earlier in the thread is no longer relevant for this model - my fault!
You have a 'Code Unit' that handles the confidential code and authorises starting.
So can you explain what you have on the van now?
1) Do you have the original Code Unit ECU or a Donor unit?
2) Do you have the keys for both these units?
And finally what are you trying to do now? is the vehicle starting?
There is an emergency procedure to start the Van if you have the correct code for the Code Unit ECU, where it is not working.
If you can let me know what the situation is and what you are trying to do I might be able to help further.
Fra21r+
Hi Marc
back to its original spec and one key but no transponder,
I have two new transponders to code in
Have vpo and 5 number security code
Van does not start as no transponder present
With the security code I can enter the code through the acc pedal procedure and the van starts
Want to code two transponders to the van
- x 6948
Ok, so you know the emergency starting procedure using the accelerator pedal.
As for the Transponder and the remote controls - there are 2 procedures it would seem: One to code the memorise the Transponder and one to memorise the remote control:
Keys with distance remote control
This system permits locking/unlocking of the vehicle from a distance:
Synchronisation of the keys with the remote control
Synchronise the remote controls with the radio frequency receiver in the following cases:
Select in succession the following menus:
"RADIOFREQUENCY RECEIVER"
"PROGRAMMING"
"PROGRAMMING"
N.B.: Do not confuse the "password" used for the memorisation of remote controls, with the electronic code inscribed on the code control unit and used for the memorisation of transponders.
When memorising a new key into the immobiliser unit
It is necessary to carry out the following operations:
a) Whether the confidential code in the 'Code Unit' matches the one entered; or
b) Whether the confidential code in the Engine ECU matches the one stored.
Code Unit Code Check:
ECU Code Check:
- front doors
- Rear doors
- The side sliding door
- Memorisation of a new key with the remote control in the code control unit
- Replacement of the radiofrequency receiver
"PROGRAMMING"
"PROGRAMMING"
- Memorisation of the transponder
- Memorisation of the remote control of the new key of the vehicle
| Stage | Operations to be performed |
| 1 | Connect the diagnostic equipment to the vehicle |
| 2 | Select "DIAGNOSIS" |
| 3 | Enter the type of vehicle then its chassis number |
| 4 | Select the "anti-theft" item ; Then validate with "*" |
| 5 | Select the "Code Unit" item ; Then validate with "*" |
| 6 | Select the "Configuration" item |
| 7 | Select the "key reading" item |
| 8 | Enter the confidential code (Electronic Code indicated on the customer’s confidential card) |
| 9 | The diagnostic tool checks that the code entered corresponds to the code stored in the "Code Unit" ECU |
| 10 | 2 possibilities: - The diagnostic tool displays the parameters of the key: The code entered is identical to that stored in the "Code Unit" ECU - The diagnostic tool displays "code incorrect" : The code entered is different from that stored in the "Code Unit" ECU |
ECU Code Check:
| 4 | Select the item "Test by function" |
| 5 | Select the item "power train" ; Then validate with "*" |
| 6 | Select the injection system ; Then validate with "*" |
| 7 | Select the "actuator test" item ; Then validate with "*" |
| 7 | Select the "miscellaneous tests" item ; Then validate with "*" |
| 8 | Select the "immobiliser" item |
| 9 | Enter the confidential code ; Then validate with "*" |
| 10 | Try to start |
| 11 | 2 possibilities: - The engine starts: The code entered is identical to that stored in the engine management ECU - The engine will not start: The code entered is different from that stored in the engine management ECU |
Fra21r+
Am I correct in saying the code for the transponder coding Is on the gray control unit below the steering wheel ? For coding the transponder... Rather than the 5 number password
Fra21r+
OK... ECU Code Check as discribed above
using the 5 number password ... Vehicle starts
No remote control open/ close fitted to vehicle
- x 6948
You answered before I could respond - been putting up another procedure elsewhere - but glad it is all cushty now
Fra21r+
But that only bypasses the system doe it not?.. . Ie no transponder coded in key... .. how do I program the new transponders to the ecu.
Sorry for being a pain
From prevois post yesterday
So refit original ecu and relevant parts
Reconect battery
Start laptop in lexia select citroen jumper mk2
Enrer vin
Global test
Code unit Yes Yes(highlight)
Select. Next
Ecu code FIAT.. validation to continue? Fiat
Verifie
Configuration *
Key programming *
Must have key.. continue*
Entry customer code 5 digit code nubers supplied from citroen *
Key code incorect
Enter said code throw acc pedal van starts
Reconect battery
Enrer vin
Global test
Select. Next
Verifie
Configuration *
Key programming *
Key code incorect
- x 6948
Oh, I thought for a minute you said it was working when you said it started!
To be honest the system on these is a bit Carlos Fandango, no wonder they upgraded it
. I have another load of blurb on it, but I've never had one of these so I can't say from personal experience how you actually get the thing to programme, assuming there is no fault. So do you also have this 'Electronic Code' they refer to?
Anyway, not sure if this is a help or a hinderance, but here is some more info:
Registering the keys
The key identifier must be stored in the immobiliser unit to allow the vehicle to be started. The immobiliser unit can store a maximum of 8 keys.
CAUTION: To store a new key in the immobiliser unit , All keys must be reprogrammed.
The transponder identifier of a lost or stolen key is erased from the immobiliser unit’s memory when the keys still in the customer’s possession are reprogrammed (remote controls for keys with HF remote controls are programmed from the radiofrequency receiver ECU).
Access PARAMETER MEASUREMENTS to ascertain the status of the engine immobiliser (NUMBER OF KEYS AUTHORISED and KEY STATUS).
Use the diagnostic tool.
Select the menu: Configuration.
After validating and to access one of the following procedures:
Reading
CANCEL ALL KEYS
The tool will ask for the LOGIN or ELECTRONIC CODE on the code card used by the network to be entered.
This code is used to unlock the immobiliser unit and is also used, amongst others, to program keys.
If the user enters an incorrect code during the login procedure three times in succession, the immobiliser unit will be locked for 30 min.
N.B.: The electronic code and the mechanical code are given on the code card.
Purpose of the electronic code:
Select the menu: Registering the keys.
After validating, the tool asks for the LOGIN or ELECTRONIC CODE to be entered.
If the LOGIN is recognised by the immobiliser unit, follow the procedure on the diagnostic tool below:
Entering the key number to be learnt
To memorise the key: Put the key to be programmed in the ignition on position, Engine stopped
N.B.: The tool displays the number of keys memorised.
If the initialisation procedure fails:
Replacing the immobiliser unit
The network must perform the following operations when replacing the immobiliser unit:
Fit the new immobiliser unit, supplied blank (programmed with the secret code, the fixed code and the electronic code) On the vehicle
Program the identifiers of all keys in the customer’s possession into the immobiliser unit
Reminder: Non memorised or lost keys will be cancelled from the list of authorised identifiers by the immobiliser unit.
After validating, the tool then asks for the LOGIN or ELECTRONIC CODE to be entered.
If the LOGIN is recognised by the immobiliser unit, follow the procedure given on the diagnostic tool:
To memorise the key: Put the key to be programmed in the ignition on position , Engine stopped
N.B. : The replacement parts department is able to provide an immobiliser unit with a secret code and fixed code identical to the previous unit . A database accessible to the department allows the details of the engine immobiliser to be ascertained from the vehicle’s chassis number:.
- Fixed code.
- Key identifier (1 to 8).
- Secret code.
- Mechanical code.
- Electronic code.
- Password (programming of HF remote controls).
Reading
CANCEL ALL KEYS
- To program the keys
- To perform the emergency starting procedure or engine ECU forced unlocking procedure
- Refer to the list of error messages
- Press return to go back to the procedure
| Message | Description |
| Aerial faulty Disconnected | Defective antenna Repair the harness Replace the aerial |
| Key not valid | Transponder absent or not suitable Key with an unknown identifier Key faulty |
| Key already programmed | The key in the ignition has already been initialised Press key (*) to validate Initialise a different key |
| Key cancelled | The identifier of this key has been erased from the list of authorised identifiers to be stored in the immobiliser unit The key can no longer be recognised |
| Secret code not valid | The key has been programmed with a secret code (1) which is different to the one stored in the immobiliser unit |
| Programming not possible | The immobiliser unit has detected a fault Initialisation cannot be performed if a fault is present |
| Maximum number of keys | The maximum number of keys which can be stored in the immobiliser unit is 8 |
| IMMO CODE in FACTORY MODE | The IMMO code is a basic code randomly generated when the transponders are programmed, from which the SECRET CODE and FIXED CODE are obtained |
- Fixed code.
- Secret code.
- Mechanical code.
- Electronic code.
Fra21r+
Thanks Marc
Yeah it started but that's just like the pedal procedure is it not as you are entering the 5 numbered password so it will start but that's not programming the transponder
This secret code where would this be or get?
As the module under the steering wheel on has it dhlfi numbers
if different from vro four number and five number password
As this is an real early mk2 (possably mk1 parts fitted) would I be better trying the jumper Mk1 in lexia for coding
- x 6948
No, the procedure is exactly for this model as per your VIN (that's why we ask for it). According to the info above it states it should be available from the dealer
Fra21r+
The way it reads..
Replacement immobiliser
Unit is is supplied with secret code is it not?
"Replacing the immobiliser unit
What a pain in the erse this is
- x 6948
I know, clear as ditch water!
Fra21r+
Thanks Marc
il let you know how I get on.... Or not lol
can always revert back to the doner ecu
Fra21r+
OK today's mission
Tried all the above options still no joy... Got right to writing to key... Then... Code incorrect
This is after entering the 5 number password and it telling me "" correct""
feck knows
When to the breakers got another ecu, grey immobiliser module with key code card and chassis number but No key ..... Just to try
From a 2004 relay
Same
It also said Fiat in options
Had enough
Doner Ecu refitted vans going fine as I have one key/transponder
Only problem I do not have chassis number or key code for this Ecu.... so the lexia is no use to read faults even
Thanks for all your help Marc
feck knows
From a 2004 relay
Same
Had enough
