Hard starting diesel
kiwifrog
Unread post by kiwifrog »
Hi, my mk 1 Xantia turbo diesel is getting a bit hard to start lately, its cranking over fine but failing to fire. Its mainly first thing in the morning and after work so is it glow plugs ? They look like they are a pain in the bum to get at, one looks like the injector pump might have to come out :(
x 1496
Re: Hard starting diesel
If, when it does start, it does so slightly stutteringly in a cloud of grey smoke, then it's the glow plugs. If however, it catches cleanly and starts without smoke, it's an air leak in the fuel system - to confirm this you can try pumping the primer before you start it to see if it improves things.
The glow plugs can be done in situ, but it's not easy! The one behind the pump is a real PITA, and is harder on later cars with the turbo outlet bolted on down the back of the engine. You need a deep offset cranked ring spanner to get them out. Only fit Beru plugs as replacements, others just won't last!
x 1746
Hi, and welcome!
Check whether voltage is reaching the glow-plugs - likely to be around 11v when they are operating.
Check also the contacts on the underside of the GP relay for overheating/poor connection.
Main contacts inside the relay can need cleaning too.
GP relays available as a new part, but get exactly the right one (post your VIN here if you need the part no.).
Beru only for the plugs, as Richard says.
kiwifrog
Thanks guys, yes lots of smoke when it does fire and makes that real diesel knock for a second . Checked voltage on a couple of the plugs that I could reach and got 11.5 volts. I can hear the GP relay click when it times out . Is the relay designed to come apart or is it a cut it open affair ?
x 1746
GP relays will prise apart.
You may have 11.5v at the plugs, but not a lot of current available, due to a dirty contact.
Much more likely is that one or more GPs have just stopped working.
Only takes one to drop out for a rough start; two out and things can get pretty shaky (literally!).
Best to replace all four if ancient.
When you get the old ones out, you can bench-test them. Tips should glow orange-hot within 5secs or so, and take about 9A each.
moizeau
x 423
Unread post by moizeau »
Warm the engine up thoroughly and a apply Plus Gas or similar prior to removal, be gentle, may have to unscrew them 1/2 a turn at a time, like cutting a thread.
Pete
kiwifrog
£ 26,84 glow plugs
Delivery
£ 149,23 ( $288 nz )
This is the only problem with living in NZ, delivery costs, cant get Beru here.
x 1473
Unread post by xantia_v6 »
You can use a mail forwarding service that gives you a UK address for vendors and reasonable rates for forwarding to NZ.
x 1746
International post would be a tiny fraction of that.
Four GPs will fit in the palm of your hand...
kiwifrog
white exec wrote: 25 Feb 2019, 18:42 International post would be a tiny fraction of that.
That price was from buycarparts.co.uk
x 1496
Royal mail air mail service to NZ for a small package is £5-£7 depending on whether it comes under 250g or not. I'd be happy to procure some Beru plugs and post them out to you.
kiwifrog
RichardW wrote: 26 Feb 2019, 07:24 Royal mail air mail service to NZ for a small package is £5-£7 depending on whether it comes under 250g or not. I'd be happy to procure some Beru plugs and post them out to you.
Yes please ! get me a total price and I will pay you via your prefered method :) :) :)
x 1496
OK, I'll see what I can do.
x 1496
Found them on e-bay for £8.09 each, Free UK delivery: BERU plugs - the ad implies that they will post internationally, and the price seems right - £7.50 for a tracked service (only £1.60 for a non-tracked service, but I can't find that on RoyalMail, so I am sceptical! I can try and order them for direct delivery?
kiwifrog
Thanks Richard, ive asked the seller to confirm shipping cost to NZ
