Hello again, long time no speak to.
My old Synergie is still going strong but I need to replace the driver's side wiper arm. The old one is getting wobbly and hasn't had the strength to get the wiper blade to make proper contact with the screen for some years now.
Obviously I'm struggling to find the part so I'm wondering if anyone knows if the arms off the Dispatch van are the same? Also, will the arms off the later Dispatch van fit? They're a lot easier to find on eBay.
Any help would be much appreciated.
Regards.
Ian.
95 Synergie wiper arms.
Ianhw77k
1995 Citroen Synergie 1.9TD (Mine)
2001 Citroen Xsara Picasso 2.0HDI (The wife's)
- x 6957
Re: 95 Synergie wiper arms.
Hi
No longer availabel from Citroen, but the part numbers are:
6429 E4 - Right
6429 E6 - Left
6429 E4 - Right
6429 E6 - Left
Ianhw77k
Thanks Marc, I'll see what I can find.
Ian.
Ian.
- x 6957
Ian - The same parts were fitted to early circa 2006 model Dispatch I & II vehicles. If you find a dispatch from about this era and want me to check, just provide me with the Reg number or the VIN and I can check for you.
Ianhw77k
Thanks again Marc, I've found loads of 2007 onwards Dispatch wiper arms on eBay but nothing earlier.
I reckon I could probably fix it but if it goes wrong, I'm without a driver's side wiper completely. There's just a lot of play on the main hinge, reckon I could turn a sleeve or hinge pin up on the lathe in no time, it could probably do with a new pair of springs in there too.
- x 3306
Try giving Wokingham Car Spares a shout. I was in there earlier, and they had a Dispatch (and the Pug equivalent), but I cannot remember what year they were. If I had remembered this post I would have got more details to take with me.
- x 6957
Let me know the VIN or reg of the 2007 model - you may be in luck.Ianhw77k wrote: 13 Feb 2019, 19:11 Thanks again Marc, I've found loads of 2007 onwards Dispatch wiper arms on eBay but nothing earlier.
kenbw2
- (Donor 2017)
- x 24
Can confirm my 1999 Dispatch has the same part numbers as the ones posted above
Anything stopping you getting one from a scrappy?
Ianhw77k
Finding one at a scrappy is the main problem, these vehicles are getting a bit thin on the ground.
I'm putting the word out.
