Intake manifold gasket
zeeshanzaki
- x 6
I have to replace intake manifold gasket in c5 v6. I found similar on eBay but just wondering if I can use gasket maker sealant instead of oem gasket.
- x 1454
Re: Intake manifold gasket
I guess we are talking about a petrol V6 with an ES9 engine?
In principle a silicone sealant can be used, but it is likely to cause more work next time the manifold is taken off because it will need to be cleaned off and kept out of the inlet ports.
I would have thought that the gaskets would still be available cheaply from a PSA dealer, or after-market parts supplier.
zeeshanzaki
- x 6
I will apply the gasket and leave to dry, so when I put it back on the engine it will not stick. This way it will be easier to remove next time.
chinkostu
- x 30
the gasket tube stuff is designed to spread out and dry and turn into a gasket, filling imperfections when torqued down. if you let it go off then fit it i'd imagine it'd just blow or have not dried flat.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
