Hi guys
I know this is a subject well covered but i have read everything i can find and i am still struggling . My window did the old open on its own thingy sometime ago so i followed advice and disconnected and left it shut. I aquired a complete new window and fitted but it wont open the microswitch works and 12v across the actuator energises it my understanding is the black is a common earth the pink is the supply to the heated rear window which works and the thin yellow is supply to the microswitch but if i measure continuity across the window i only get a bleep between pink and one connection on the bottom of the screen for the micro switch which i assume is not right so i bypassed all the internal screen wiring and still nothing i followed the yellow wire back which turns to red and then purlpe in a connector in the side trim on the passenger side and that disappears god knows where. the wires in the corner of the tailgate are fine so i am now confused any help ,diagrams etc would be most grateful ,inncidently has anyone modded it like a renault scenic i knicked 12v from the number plate light so the boot would open happy to do this if thats the only way to get working
thanks Robin.
c5 estate rear window operation
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5644
Re: c5 estate rear window operation
Pop up your VIN and I'll see what I have in the wring diagram department.
- My Cars: 73 stag,86 bx gt 89 bxgti 90 bxgti 4x4 91 metor auto 97 p38 2004 c5 2.0 vtr 2006 c5 estate 1.6
vin is VF7**************[VIN obfuscated, can be read by forum staff] 2006 1.6 hdi thanks
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, here you go.
I'll put the schematic on the next post.
6283: tailgate opening switch
6284: tailgate window locking actuator
6285: rear window open switch
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
thanks very much i will try and get my head round that lot in the morning
ok with a bit of head scratching and the desire to have the car back in one piecei ran two new cables from the micro switch to the connector above the glass put everything back togehter and turned on the ignition to move the car and the dash came up with the message boot window open which i thought strange as it was shut ,but i thought i would check anyway and it was secure so i pressed the microswitch and the bloody thing opened! and since lunchtime has worked fine work that one out because i am still in shock!
