Xantia 2.0 HDI late model with AC - radiator fans
- x 1751
Re: Xantia 2.0 HDI late model with AC - radiator fans
Assume similar to XM (put me right if this isn't so)...
Two radiator fans.
Should operate in series (for slow/1st speed)
Should operate in parallel (for fast/2nd speed)
Series-parallel operation is done by the three interconnected relays up front.
Switching on AC will automatically turn fans on to slow speed (to cool AC rad).
Fans should never operate one at a time; if they do, there is either a fan fault, or a relay fault.
Fans are usually separately fused: two Maxi fuses near the battery.
Pulling the connector for the temp sensor will do as described: very brief slow speed, followed immediately by fast speed*. IIRC, reconnecting doesn't stop the fans - you need to switch off IGN and back on again to revert to normal operation. *A safety feature in case of sensor failure.
Correct circuit diag for the car will confirm.
Two radiator fans.
- x 5633
Or a sticking/seized fan motor.
Poke it with a stick - don't put your fingers anywhere near them as they can start up without warning.
- x 1751
A seized fan will either be a short circuit
- this will cause the other fan to run at fast speed on its own, when both should be running at slow speed
- this should blow its maxi fuse, if it gets asked to run at fast speed
or open circuit
- slow speed will not happen
- in absence of this, engine will run hot until fast speed is called for
- then the working fan will run fast
or open circuit
Pshemsky
admiral51 wrote: 09 Dec 2018, 16:57 According to the info in the post i linked to both should spin full speed when that sensor plug is removed.
I would be inclined to remove the fan that does not work and apply 12v directly to it, that will determine if the fan itself is at fault and as you have spares it should only cost time and effort, be aware that 12v will set it on full speed so keep fingers well away from the blades.
Can i ask if your aircon is working, does the compressor kick in and if so do you get both fans spinning at slow speed.?
I am used to the MK1 Xantia fan problem so as i now have a MK2 with issues i am keeping a close eye on this thread
Right. So with cold engine direction set on screen and A/C button pressed I've noticed that AC compressor not kicking in. After a minute or two one fan (drivers side) goes with full speed for about 10-15 sec and then goes off. Situation repeats every few minutes.
PS: AC system got a pressure to operate, so not sure why it won't start.
myglaren wrote: 09 Dec 2018, 17:07 Or a sticking/seized fan motor.
Tried that already - spins freely but no reaction. I had seized motor in m XM few years back, so that was a first thing which I did to this Xantia
"There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die."
Fear and Loathing in Las Vegas
admiral51
- (Donor 2026)
- x 394
Not sure on the above, MK1 Xantia yes, MK2 replaced the Bitron and fan activation/speed is activated by an ECU.
Info is contained Here
admiral51
- (Donor 2026)
- x 394
Sorry was replying to posts earlier
- x 1751
What I described above was the classic arrangement with two fans and three relays, which were triggered by Bitron/ECU on later models, rather than the old-style 'thermo-switch' of BX and CX.
Might be a good idea, Prem, to post your VIN, so we can check RP and an exact circuit diagram, to avoid mis-diagnosis.
No shortage of advice on this pre-Christmas Sunday!
Pshemsky
I'm really impressed !!
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Thanks Chris
PS: It's bit too dark now and I'm on my way to work, but tomorrow I'll check A/C fuse and one of fan's fuses for start.
KennyW
- x 163
If you have disconnected the temp sensor and only 1 fan spins, have a look at the relays between the fans in a black triangle plastic box.
Make sure they are clean and have not suffered from overloading and melted plastic holders.
If this is the case you will have to check the continuity through the system.
On my Xantia it was broken wire in the harness.
I remember much cursing when I was testing the wiring
If you search on the forum there are plenty of threads on the subject look in the a/c section.
Kenny
Kenny
C3 1.4 petrol (SWMBO)
admiral51
- (Donor 2026)
- x 394
Does anyone have a link to which 2 wires need to be bridged to activate the aircon clutch and the other 2 to set the fans to full speed.
Distant memory says there are 2 thick and 2 thinner wires on the plug to the air dryer but having had a quick look on my MK2 Xantia the wires are not as identifiable as i remember
- x 1751
Can we pull up a cooling fan circuit for Prem's VIN? I don't have one here.
KennyW
- x 163
Have a read of my post from 2006 below which details a similar problem
https://www.frenchcarforum.co.uk/forum/ ... 12&t=19296
Kenny
Sorry it's a bit of read
Kenny
- x 6963
I’ll have a look at the circuit if it is there shortly.
admiral51
- (Donor 2026)
- x 394
Just a thought, this forum is awesome
admiral51
- (Donor 2026)
- x 394
This is my Vin for a 2000 w plate 2.0 HDI if that helps
