Leaking Rain water
Dedicated to owners of Citroen GS and GSA models.
tony trans am
Leaking Rain water
Unread post by tony trans am »
My LHD GS lets in water when it rains, it runs down to drip off brake pedal switch, nothing is immediately obvious, windscreen rubber looks good. Is there a common fault?
x 1238
Re: Leaking Rain water
Unread post by Peter.N. »
I had something similar on a 406, not quite the same I know but that was because the grommet on the bonnet pull cable had been pulled out which is directly above the pedals, ended up scrapping the car as it soaked the electronics - you won't be having that problem on yours!
x 1873
Could be leaves blocking the drain holes under the bonnet - wherever they might be!
x 5592
Paul-R wrote: 02 Dec 2018, 10:39 Could be leaves blocking the drain holes under the bonnet - wherever they might be!
I had the same and there is a rubber 'vent' thing at the top of the wheel arch, squeeze it so it opens and loads of crap and water will come out.
Flush it out with a hose once it is flowing to clear out any remaining debris.
sonoramicommando
x 5
Unread post by sonoramicommando »
myglaren wrote: 02 Dec 2018, 10:43
My GSA had the same problem - an "L" shape rubber hose, aft of the front wheel arch, was choka full of leaves and mud essentially.
I pulled mine right out and gave a good flush with a garden hose. LHS was easier (actually, not sure if I did RHS) as the LHM tank isn't there but still a bit awkward, good to have someone with flexible arm and small hand to help you.
It was so bad the car used to make sloshing noise when I drive on bends (as GSA leans a lot) - quite funny now I think about it.
2006 C6 Exclusive 2.7HDi
1982 GSA Pallas
A couple of bikes
A boyracer car ;)
