C4GP EGS Gearbox removal (video)
Chefslot
- x 14
Also related to this post viewtopic.php?f=3&t=61093&start=30
Not to sure how long this took me as was in no rush, Marc not to sure if you know the estimated time Citroen would give?
- x 6963
Re: C4GP EGS Gearbox removal (video)
Thanks for posting that Chef - was that your video? It's a swine of a job and not for the faint hearted. I just hope you can now resolve the issues with repair / replacement / programming.
Delvey
- x 6
Excellent video, and it kind of makes me glad I have sold mine.
Chefslot
- x 14
GiveMeABreak wrote: 27 Nov 2018, 11:56 Thanks for posting that Chef - was that your video? It's a swine of a job and not for the faint hearted. I just hope you can now resolve the issues with repair / replacement / programming.
Hi, yes my video, my mums car. Sorry for the late reply, didnt see any notifications. Still got a video coming of it going back together. Apart from that I really could do with some torque setting for the;
/ Central Slave Cylinder, appears they have had loctite on,
/ Pressure plate bolts, reuse?
/ Bell housing bolts,
and the suspension nuts and bolts, i think i can get most of the suspension torque settings from the haynes manual i brought, haynes have cut down on their books, so had to use a generic C4 manual. I'm guessing they are the same, but just want to check as it's a different weight class. So for this,,
/ Wheel bearing nut,
/ sub frame bolts,
/ steering rack nuts,
/ control arms,
/ steering joints,
/ roll bar,
Theres possible a few more, and if there is any thats torque to sheer obviously i could do with replacements.
Thank you Marc.
- x 6963
Leave it with me - just got back from town where the dipped beam bulb went on the other C3 and I've had to give up on changing the bu**er - near impossible to release the bloody stupid retaining clip and no room to get your hand in! I think it would of been easier to attempt what you're doing that changing a bloody bulb on a C3!
I'll get some torque settings for your shortly.
- x 6963
Ok, sorry about the delay - here you go - I've also included the Piloted Gearbox Settings too in case Haynes have it all wrong as commonly happens
Aything else missing, let me know.
Subframe
(*) Always to be replaced whenever removed
Struts
| Reference | Designation | Tightening torque |
| (1) | Bolts and nuts Coupling of gearbox on engine | 5,4 daNm |
| (2) | Screw fixing the hydraulic clutch bearing | 2,2 daNm |
| (3) | Screw fixing the gearbox impacter | 6 daNm |
| (4) | Screw fixing the piloting actuator | 2,2 daNm |
| (5) | 6th gear cover fixing screw | 2 daNm |
| (6) | Gearbox housing / clutch housing fixing screws | 2,2 daNm |
| (7) | drain plug | 4 daNm |
| (8) | Pressure accumulator | 8 daNm |
| (9) | Union (High pressure pipes ) | 2,2 daNm |
| (10) | Union (High pressure pipes ) | 1,8 daNm |
| (11) | Flange retaining screw | 1,8 daNm |
| (12) | Input shaft end piece bolt | 18,2 daNm |
| (13) | Output shaft end piece bolt | 10 daNm |
| (14) | Closer on the 3/4 fork balls channel | 1,6 daNm |
| (15) | Closer on the 5/6 fork balls channel (reverse gear) | 4 daNm |
| (16) | Linking bracket screw | 2,3 daNm |
| (17) | Bolt Input shaft rotation sensor | 1 daNm |
| (1) | Bolt (Front subframe extensions) | 5 daNm |
| (2) | Nut (Front sub-frame tie rods ) | 2 daNm |
| (3) | Bolt (Front subframe) (*) | 9,8 daNm |
| (4) | Bolt-nut assembly (Lower suspension arm / Front subframe) (*) | 11,1 daNm |
| (5) | Bolt (Front anti-roll bar bearings) (*) | 10 daNm |
| (6) | Bolt (Front subframe rear mounting reinforcement / Body) (*) | 10 daNm |
| (7) | Bolt (Front subframe front lower crossmember ) (*) | 5 daNm |
Struts
| (1) | Nut (Suspension strut / Body) (*) | 7,5 daNm |
| (2) | Nut (Front damper upper cup) | 8 daNm |
| (3) | Nut (Front anti-roll bar rod / Front shock absorber) (*) | 4,3 daNm |
| (4) | Nut (Front anti-roll bar rod) (*) | 4,3 daNm |
| (5) | Nut (Front pivot lower ball-joint / Lower arm) (*) | 4,2 daNm |
| (6) | Nut (Front pivot lower ball-joint / Front pivot) | 23 daNm |
| (7) | Hub nut (*) | 31,2 daNm |
| (8) | Bolt-nut assembly (Damper spring assembly / Front pivot) (*) | 8 daNm |
Chefslot
- x 14
GiveMeABreak wrote: 01 Dec 2018, 14:44 Leave it with me - just got back from town where the dipped beam bulb went on the other C3 and I've had to give up on changing the bu**er - near impossible to release the bloody stupid retaining clip and no room to get your hand in! I think it would of been easier to attempt what you're doing that changing a bloody bulb on a C3!
Holly cow Marc, thank you very very much, i think that is all except how tight to do up the cookie jar!!
Oh the days of changing a megane 2 bulb,,, they will always stay with me!!
Chefslot
- x 14
Sorry just a little more advice, the torque on the steering rack to sub frame, should be two nuts and there is also a engine mount, drivers side bottom to subframe.
Also does it suggest to put the car back together before bleeding and resetting the EGS? I would assume so as it would need to know where the biting point is?
Regards
(i think that is it, lol)
Regards
Chefslot
- x 14
Subscribing to thread
- x 6963
Here you go Chef: I'll see what I have on the last point of your question shortly.
RH Engine Support
LH engine support
Lower engine mounting
MCP Piloted Manual Gearbox
| (1) | Nut (Steering universal joint / Valve stem) (*) | 2 daNm |
| (2) | Bolt (Steering column / Crossmember) | 2,2 daNm |
| (3) | Nut (Steering column / Crossmember) | 0,7 daNm |
| (1) | Nut (Steering ball joint) (*) | 4,5 daNm |
| (2) | Union (Hydraulic pipe / Distribution valve) | 0,8 daNm |
| (3) | Bolt (Bracket / Distribution valve) | 1,9 daNm |
| (4) | Bolt (Distribution valve / Steering mechanism) | 2 daNm |
| (5) | Union (Hydraulic pipe / Steering ram) | 0,8 daNm |
| (6) | Stud (Steering mechanism) | 0,9 daNm |
| (7) | Nut (Steering mechanism) (*) | 10 daNm |
| (8) | Steering rod | 7 daNm |
| (9) | Locknut (Adjusting the steering track rods) | 7,5 daNm |
| (1) | Nut (Electro-pump / Chassis leg) | 2 daNm |
| (2) | Bolt (Bracket / Electro-pump) | 2 daNm |
| (3) | Bolt (Electro-pump / Chassis leg) | 2,3 daNm |
RH Engine Support
| Reference | daNm |
| (1) | 6 ± 0,6 |
| (2) | 6 ± 0,6 |
| (3) | 4,5 ± 0,4 |
| Reference | daNm |
| (4) | 1 ± 0,1 |
| (5) | 6,5 ± 0,6 |
| (6) | 1,9 ± 0,2 |
| (7) | 3 ± 0,3 |
| (8) | 6 ± 0,6 |
| (9) | 5 ± 0,5 |
| Reference | daNm |
| (10) | 6 ± 0,6 |
| (11) | 4 ± 0,4 |
| Reference | daNm |
| (14) | 6 ± 0,9 |
- x 6963
As for Depressurising / Pressurising & Bleeding:
1. Depressurizing the system
- Connect the diagnostic equipment to the vehicle’s diagnostic socket.
- Switch on the ignition.
- Using the diagnostic tool : Select : Depressurisation of the hydraulic circuit.
- All the oil contained in the electrohydraulic actuator unit and in the pressure accumulator returns to the piloting actuator hydraulic reservoir.
- The piloting actuator hydraulic circuit is no longer pressurised.
- Using the diagnostic equipment : Select : Pressurising the hydraulic circuit.
- The electric motor of the electrohydraulic actuator unit operates for a few seconds.
- The piloting actuator hydraulic circuit is pressurised.
- Select: In the diagnostic tool menu :
- The vehicle
- The RPO no.
- Perform the global test.
- Using the diagnostic equipment: Select: Bleeding the hydraulic circuit.
- The diagnostic tool pressurises the piloting actuator hydraulic circuit, changing through all the gears in order to force air out of the circuit.
Chefslot
- x 14
Marc you are a legend!!!!
I take it all this is done when the car is put back together on four wheels? Also once these 3 steps are completed is there anything else like reprogramming the biting point or is this all done automatically?
Regards
Regards
OnlineRichardW
- x 1470
Note you will need an external power supply to get it to program, battery charger or jump it off another (running) car. There might be a clutch adjustment in Diagbox, otherwise just pull away hard a few times.
- x 6963
Glad it helps - Richard's your man for the programming of these systems as I run in the opposite direction if I see one!
Chefslot
- x 14
I know what you mean Marc, disliked the Renault Clip, hoping this one will be a little easier on the brain.
Thank you Richard, will be picking your brain no doubt.
Regards all
Regards all
