Hi got a replacement on flea bay one of those sold many places type.
What i found when had a look the wires are too short!!! about 50mm odd the one that goes to column and ones to fuse board about 20mm
So be warned i did get onto them and they gave me a refund straight away probably knew about it?
Thinking maybe splice it into old plugs with some soldering and heat shrink or take old switch apart and put new bits into it? so have a spare as lucky took the one out of car i scrapped while back
Replacement Ignition switches
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5723
Re: Replacement Ignition switches
Maybe it's time you updated your profile to at least list your current vehicle as currently nobody knows what you are referring to.
- Location: London near that big building with the flashing light!
- My Cars: 2001 Xsara Picasso 2.0 HDi
- x 8
GiveMeABreak wrote: ↑31 Oct 2018, 09:12 Maybe it's time you updated your profile to at least list your current vehicle as currently nobody knows what you are referring to.
There the common Peugeot/Citroen and other cars one was just a warning to others needing to replace there's! more than one particular car.
